can you bypass ECM - Dodge Cummins Diesel Forum
post #1 of 44 (permalink) Old 09-04-2011, 09:24 PM Thread Starter
wbski007's Avatar
can you bypass ECM
I have a 93 D250, is there anyway to bypass ECM compleatly, my ALT is not charging, OD not working as it should, speedometer is reading 7MI slow and the motor is smoking bad on startup, a rebuilt ECM is $199 if I can get one, Autozone and O'RiLeys can't get one, their on back order. I just hate computers anyway, I say keep it simple and you'll have less problems, any help out there?? I mean its only got 372,000 miles on her, she's not even broke in yet, but this is the 3rd ECM gone bad, thanks Wayne
wbski007 is offline
post #2 of 44 (permalink) Old 09-04-2011, 09:41 PM
Moderator
9297oldram's Avatar
You sure can it's easy if it's a 5 spd. Speedometer I use a Garmin has a speed and trip miles so you can keep track of your miles. Charging problem use a external regulator or a 1 wire alternator. Grid heaters use a push button to energize the grid solenoids. If it smokes bad on start up could be time for new injectors. If you have a auto trans someone should be able to help you on bypassing it.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 SC zf5, 4x4, SAS, 92 Cummins, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod, WM, wh1c hybrid 60/64/.82a/r
9297oldram is online now
post #3 of 44 (permalink) Old 09-04-2011, 09:51 PM Thread Starter
wbski007's Avatar
thanks for the quick repley, Its a auto trans, yes I can use a 1 wire alt or put in a voltage regulator from a older model, any hints on how to wire a older regulator in??and I do have a garmen, that's how I know the speedo is 7 miles off, is that all the ECM runs is ALT, OD and starting, it never smoked untill the ECM went bad, does the ECM control the TPS also??? it must!
wbski007 is offline
post #4 of 44 (permalink) Old 09-04-2011, 10:03 PM
Moderator
9297oldram's Avatar
If you use the google box at the top left of the page and put in external regulator you will find a lot of threads on this also there is a tech section that I believe has some assistance on wiring one in. The ECM tells the grid heaters when to come on I can help you with a push button for that. I believe there is a way to bypass the Trans but I don't know anything about it. Try unplugging your KSB to see if it still smokes when you start it.
post #5 of 44 (permalink) Old 09-04-2011, 10:11 PM
Moderator
9297oldram's Avatar
Chrysler Dodge & Jeep Alternator ECU External Voltage Regulator Bypass this place has a kit for your regulator. From I have read in other threads don't buy a cheap regulator.
post #6 of 44 (permalink) Old 09-04-2011, 10:29 PM Thread Starter
wbski007's Avatar
thanks OLDRAM that's just what I was looking for, I just ordered one, good going mate, Wayne
wbski007 is offline
post #7 of 44 (permalink) Old 09-04-2011, 10:32 PM Thread Starter
wbski007's Avatar
I never have to use the grid heaters here in FL, so their no problem, I even have a remote start hooked up and she just fires off every time.
wbski007 is offline
post #8 of 44 (permalink) Old 11-15-2013, 02:46 AM
redneckforlife's Avatar
If u eliminate the PCM wouldn't that mess ur water in fuel light and most of the gauges on the dash. Or is there a way to wire it in so all u gauges still work
1991 cummins none inter cooled 5speed all stock
redneckforlife is offline
post #9 of 44 (permalink) Old 11-15-2013, 08:43 AM
coupenasty's Avatar
im not sure but the tps delete might help you with your o/d problem. i think its dnr customs that sell them there like $40. i installed one on my truck and it fixed my o/d issues. im just not sure how it works with the ecm.
coupenasty is offline
post #10 of 44 (permalink) Old 11-15-2013, 09:39 AM
Ducati M.
DMan1198's Avatar
I drove with my computer blown and all my gauges worked. These trucks are simple enough that they don't really need the computer for everything to function. I don't know about the water in fuel. That's just because I've never had water in my fuel
Jaeger-12 ram 3500, CCLB, 68rfe, 2" lift, 5" tbe, steed, s476, MM w/MCC, OD, ISSPRO factory match, ARP 625's, Hamilton 103's/extreme duties, T/Rex traction bars, mag hytec trans pan,
v2 Finally doing stuff
The Roo Hunter- 93 w250, g360, np205, 4" lift, custom 3/8" bumper, Hellman sump, raptor 100, dual filters, ddp stg 3's and pin, steed, modded hybrid wh1c/hx40/s467fmw compounds 4" tbe, autometer cobalt series.
Instagram:
DMan1198 is online now
post #11 of 44 (permalink) Old 11-15-2013, 02:27 PM
Moderator
9297oldram's Avatar
The 92 and 93's you'll loose the internal regulator and i believe the speedometer and any functions controlled by the CPS. The gridheaters won't work but you can put them on a push button.
post #12 of 44 (permalink) Old 11-15-2013, 03:29 PM
Ducati M.
DMan1198's Avatar
Yeah I had to run a regulator but I didn't lose my speedo. I did lose cruise control and the grid heater.
Instagram:
