rear axle wheel. seal - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 08-11-2011, 11:05 AM Thread Starter
My 93 dually has a 70u rear axle, I have replaced the seals 2 times and they still seap. Where can I get speedy sleves for it?
anita is offline
post #2 of 7 (permalink) Old 08-11-2011, 12:43 PM
Moderator
9297oldram's Avatar
Anyplace that sells the seals should be able to get the speedy sleeves.
92 D250 parted out
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 4x4 with 92 Cummins zf5
9297oldram is offline
post #3 of 7 (permalink) Old 08-11-2011, 08:50 PM
most of the parts stores carry them...of course, if you get a young kid behind the counter, he'll have a clueless look on his face if when you ask for one...haha
91 non I/C. W350 flatbed SRW
1997 drw flatbed
hounddogks76 is offline
post #4 of 7 (permalink) Old 08-12-2011, 08:09 AM
A couple questions since I know these are a pain to pull apart. sure it's not a leaky wheel cylinder? Lubing the spindle so the seal isn't dry on install (that will burn the new seal right away) Bearings not loose and allowing the hub to wobble and break the seal? Is it leaking between the spindle and seal or the seal and hub (a gouge in the hub from pulling out an old seal will cause a leak, clean the scratch and a light smear of silicone helps this) If the spindle is rusty, gouged or grooved a speedy sleeve will fix that but not the other problems.
Ruderunner is offline
post #5 of 7 (permalink) Old 08-13-2011, 01:10 AM
absent_heart's Avatar
Check that the axle vent tube is not obstructed.
I had the same problem with perpetually leaking wheel seals, when i was swapping to rear discs I noticed that a previous owner capped the vent line. So when it got hot and pressure built the wheel seals were the weakest link.
93 D-250, NV4500 with US Gear overdrive (poor man's 10 speed), 3.73 Gears, Stock Injectors, 12cm turbo, Pump screw bottomed, 4" Exhaust, Rear Disc Brake Conversion, Denny T Fuel Pin, AFC spacer, Cable Shutdown Club. Unbranded Exhaust Brake
absent_heart is offline
post #6 of 7 (permalink) Old 08-13-2011, 08:46 AM
Make sure your getting the oil seals, There are grease seals The lip on the seal is differant and they will seep if not for oil.
2017 MegaCab Limited, DRW, 4x4, Aisin w/ 4:10's, SuperGlide ISR 24K, DuraFlaps
fitter48093 is offline
post #7 of 7 (permalink) Old 02-13-2012, 03:39 PM
dodge bill's Avatar
This really helped. I'd never heard of speedy sleves so I'll check into it. I do have grooves but of note, My axle vent was completely plugged up. It wasn't evident at first because the tube was fine. It was the tapped fitting into the tube that was plugged up airtight. Thanks for the help.
dodge bill is offline
