Ball Joint Socket Help Fast - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 05-11-2011, 02:18 PM Thread Starter
Hey yall I need to know what size socket to use to take out my upper ball joints and maybe where to get one. I tried all the local part stores. Im gonna try to gp to a tool store today and get a big socket but I was just needing help on the size. Thanks.
95 Dodge 2500 Crew Cab 4x4 v10 awaiting a Cummins swap within the next year.
smalltowmfarmer is offline
post #2 of 10 (permalink) Old 05-11-2011, 03:47 PM
deanhinsley1963's Avatar
it takes a special socket for that purpose. They are pretty expensive unless you are going to be doing a bunch of them I have heard they can be done with a very large set of channel locks.
92 D-350 Dually,Reg. cab C.T.D. Auto,3.54 limited slip,gauges,BHAF,3turns on smoke screw,2 turns on fuel screw,Denny T stage II fuel pin. 366spring and m&h timing spacer next!!!!
deanhinsley1963 is offline
post #3 of 10 (permalink) Old 05-11-2011, 04:37 PM Thread Starter
I thought they would be, but I cant seem to find one. I ried using an adjustable wench but theres a lip down there on the arm it wont get on there.
post #4 of 10 (permalink) Old 05-11-2011, 10:07 PM
48kenworth's Avatar
I always use 12 inch pipe wrench and a cheater pipe. For me that works much better than the big channel locks.
89 w250 intercooled engine, G56, S300G, honed stock injectors, 366 spring , 2nd gen CAC, dakota A/C condenser.
99 K2500 suburban, 4l80E, 92 Cummins 6BTA, 6X10 injectors, HE341, 1st gen CAC 366 spring.
WTB Grey interior trim!!
48kenworth is offline
post #5 of 10 (permalink) Old 05-11-2011, 11:01 PM
90bonestockcummins4X4's Avatar
i made a socket using a piece of heavy wall square tubing and a broken 3/4 drive socket end, be carefull not 2 strip the threads out of them.
95 quadcab 4x4 90 horse sticks bhaf, 215 pump. egt boost nd fuel press on pillar ats flex, suncoast triple disk tc, locked, nv4500 soon to come
90bonestockcummins4X4 is offline
post #6 of 10 (permalink) Old 05-12-2011, 08:46 AM Thread Starter
I tried the channel locks but no luck there. I wish I could make me somthing. I rented the ball joint tool for the lower one and it was to small. Its hard to find this stuff.
post #7 of 10 (permalink) Old 05-12-2011, 11:30 PM
Hooter1's Avatar
Need to change mine also on my D350. Sounds like the uppers are screwed in and the bottoms pressed? If so, time to start soaking the tops with PB Blaster
'92 D350 5 Speed towing a 8 second '63 Pontiac drag car
4" Diamond Eye, Denny II pin, full power screw 2 turns, BHAF with homemade intake
Hooter1 is offline
post #8 of 10 (permalink) Old 05-13-2011, 12:04 AM Thread Starter
Ok everyone and Hooter1 this will help you.
Yes the upper is screwed and the bottom pressed.
I bought all of mine from ORiely's and I ran into a problem. The uppers were some cut wrong and they wouldnt fit in the socket. I found this out by ordering from Advance and they had the socket to fit and it worked perfect.
As far as the socket to fit I got it from ORiely's. They ordered it from Atlanta GA and it cost 25.00. It worked fine. But If you can rent a master kit It should have the socket in it. The normal press wont work on the pressed joins, its to small. At least thats my experience.
When I removed the upper joint I used the socket and 3/4 impact, I sprayed PB Blaster on it and it eventually started turning it out.
post #9 of 10 (permalink) Old 05-13-2011, 11:26 AM
Hooter1's Avatar
Let me know how those Advance units work out for you. I had planned on using Moog but am having a hard time justifying spending $300 on ball joints for a truck I drive maybe 5,000 miles a year.
Hooter1 is offline
post #10 of 10 (permalink) Old 05-13-2011, 12:48 PM Thread Starter
So far that one went in fine. They were about 144.00 so thats not bad.
