89 first gen wont start help!!!! - Dodge Cummins Diesel Forum
post #1 of 26 (permalink) Old 04-07-2011, 04:20 PM Thread Starter
firstgennut's Avatar
hey guys i have an 89 dodge 350 with the original first gen cummins in it it wont start where do i begin after fuel cuz i just replaced the lift pump first thought it was that because i ran it out of fuel the other day fueled it up then for a couple of days been hard to start since then just stalled while driving and will not start now i cracked one of injector lines to make sure fuel was getting there and it is what now this is my get to work vehicle and could use some help quick
thanks
firstgennut is offline
post #2 of 26 (permalink) Old 04-07-2011, 05:49 PM
W350_1992's Avatar
Check the wires to the fuel shut-off solinoid and make sure theres 12v getting to it if you hav'nt already. You say theres fuel getting to the injectors, there might not be enough for it to start.
'92 w350 Club Cab 5spd 3.54, D80 DRW with 2nd gen rear suspension, Gauges, VGT, Flow Honed injectors, Mild IP adjustments, BHAF, High Vol Piston Pump, Water/Methanol, KSB spacer, Ground Stock pin
'97 3500 2wd ext cab dually bed- currently no engine or transmission, future project
W350_1992 is offline
post #3 of 26 (permalink) Old 04-08-2011, 11:58 AM
Moderator
9297oldram's Avatar
Did you bleed the fuel system? They won't run or start good with air in the fuel system.
92 D250 parted out
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 4x4 with 92 Cummins zf5
9297oldram is offline
post #4 of 26 (permalink) Old 04-08-2011, 01:19 PM Thread Starter
How do I do these where is the shut off and what lune should I crack open to bleed the air I tried the water drain on the filter
post #5 of 26 (permalink) Old 04-08-2011, 02:00 PM
Moderator
9297oldram's Avatar
The fuel shut off solenoid is on the top side of the injector pump about in the middle will have a wire connected to the top of the solenoid. To bleed the fuel lines first fill the filter full then above the filter you will see a banjo bolt with a 10MM bolt head in the middle of it open it about 1/2 to 3/4 turn. Go to lift pump and prime the lever on the side of it until fuel with no air comes out of the bleeder screw, then close bleeder. Then crack open the nuts on top of the injectors. crank engine over until fuel comes out from the nuts and tighten them and it should start.
92 D250 parted out
post #6 of 26 (permalink) Old 04-08-2011, 02:54 PM Thread Starter
Ok assume I will try after work today if after this it still doesn't start how do I check the glow plugs and where is the relay and stuff for them
post #7 of 26 (permalink) Old 04-08-2011, 03:00 PM
Moderator
9297oldram's Avatar
A cummins uses a grid heater if you look where the intake horn is bolted to the manifold on the engine you will see a square block with big wires on each side. Read this thread Cold Starting Issues- Grid Heaters? it covers a 89 dodge.
92 D250 parted out
post #8 of 26 (permalink) Old 04-08-2011, 07:46 PM Thread Starter
well that was a huge help it started right up as soon as i did the bleeding of that ten mill banjo bolt and the injector lines but lol yup a but now i drove it up the road and it was fine till i got on it a little hard let off quick it stalled and would not start till i did all the bleeding over now i did run her out of fuel before all of this could i of screwed something up in the tank or maybe is there a line sucking in air somewhere ive been letting it idle now for about an hour trying to maybe work any air out ? thanks so much almost out of the woods
post #9 of 26 (permalink) Old 04-09-2011, 12:12 AM
W350_1992's Avatar
I would'nt let it idle too long at a time, can be rough on the cylinders. I'd say you must have a air leak somewhere. Another thing, if you ran it out of fuel, you'r fuel filter could be clogging up with gunk that got stirred up in the tank. Still sounds like a air leak to me though.
post #10 of 26 (permalink) Old 04-09-2011, 03:42 AM
Moderator
9297oldram's Avatar
If you have a leak between the lift pump and injectors you will see fuel. If you have a leak between the lift pump and pickup in the tank it will suck air. A diesel doesn't like mixed drinks, just diesel. If you still think there is air with your truck at idle crack a injector nut 1 at a time just long enough for a little fuel to run out. Use caution that fuel is very high pressure.
92 D250 parted out
post #11 of 26 (permalink) Old 04-09-2011, 07:55 PM
WOW! idling hard on the cylinders. Funny!
92 d350 auto CM flatbed, 93 w350 5 speed CM flatbed, 92 f350 Fummins 4wd 5 speed on 37s, 93 f350 Dually 4wd idi turbo, 94 f350 5 speed 4wd fummins, 96 f350 4wd auto, 97 f350 4wd auto 46s on 20s, 08 dodge 3500 4x4 auto dually CM flatbed.
supertech is offline
post #12 of 26 (permalink) Old 04-10-2011, 02:36 AM
W350_1992's Avatar
Yup, diesels run so efficiently somtimes they wont burn all the fuel at normal idle speed and wash the cylinder walls and eating the cylinders... not funny. Its best to high idle 1000-1100rpm is its gonna idle very long to keep the engine warm.
