GEAR vendor OverDrive unit - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 04-03-2011, 04:08 PM Thread Starter
1992rm250's Avatar
Question GEAR vendor OverDrive unit
Has anyone Ever bought a GearVendor Over Driver Unit For the GETRAG or NV4500 ??? i would buy one
, from what i have read , you can split gears ?
CHECK IT OUT
Gear Vendors Under/Overdrive Dodge/Dodge RAM Manual transmissions.
2006 Cummins QCLB $750 bucks bought for ( BUILD THREAD ) engine build
92 D250 , VE pumped Maxd , 4 inch to 5inch stacks , 3200 spring , bumped timing, 5speed
1976 plymouth duster 440 1973 dodge dart ProStreet
CHESTERS HEAVYDUTY TOWING AND RECOVERY
I wake up, put a dip in, crack a cold one Put my boots and my overalls on , PUT A GOOD DIP IN YEEEEE YEEEEEEEEEE
1992rm250 is offline
post #2 of 16 (permalink) Old 04-03-2011, 05:34 PM
DSTAD's Avatar
Now thats cool!!!!!!!!!!!
If only i had a 12v 5spd for a pulling truck and beable to split the gear mid pull
96 3500 2wd, ddp 2s, 3kgsk, #10 plate. Hybrid over s475, bd full roller bearing trans, DiPricol gauges, bd torq loc and tow loc, Pac brake 4 inline, Aux trans cooler with fan, Firestone ride rite with on board air/control, DSS, Centramatics, Maghytec, DDP Boost.
DSTAD is offline
post #3 of 16 (permalink) Old 04-03-2011, 06:29 PM Thread Starter
1992rm250's Avatar
IT WORKS FOR AUTOMATICS alsoo !!!!!!!!
post #4 of 16 (permalink) Old 04-07-2011, 11:59 AM Thread Starter
1992rm250's Avatar
bump for gearvendor and 3.07s gears !!!!!
post #5 of 16 (permalink) Old 04-08-2011, 02:59 AM
Winkles's Avatar
For 3 Grand.....or 3500? whoa...
RIP - 1993 W250; 60HP injectors, 366 Spring, Icebox Intake w/ S&B filter, 4" Str8 Pipe, AT w/ First-Stage Billet Converter, and 4.10 Gears. Isspro Gauges: Pyro, Tach, Boost, Tranny Temp. And of course, High-Beams on the floor!
Winkles is offline
post #6 of 16 (permalink) Old 04-09-2011, 07:16 AM Thread Starter
1992rm250's Avatar
i got a price of 2,000 i shopped around on google
post #7 of 16 (permalink) Old 04-09-2011, 07:24 AM
billow99's Avatar
It would be worth it if you did a lot of hgwy drivin. There are other companies that make em. I believe us gear is one. I would love to do this ....sometimes I go for seventh
99 2500,G56....
billow99 is offline
post #8 of 16 (permalink) Old 04-09-2011, 07:48 AM Thread Starter
1992rm250's Avatar
Well im planing on Doing 3.07s in my truck for highway crusieing and when i tow my car trailer to the Track i can Split her , up hills =)
Isnt USGEAR only for Exhaustbrakes ???
post #9 of 16 (permalink) Old 04-11-2011, 04:42 AM
Nightrainhauling's Avatar
I have a 5831 Spicer 3 speed auxiliary (brownie box) in my '92. It works Great. Run in 4th over when pulling heavy, run in double over when not.
Jason 1992 D350 Extended Custom Cab, 5.9L 12 Valve
HX35W
Diesel, PDI Manifold, Diamond Eye 4", 5 speed Getrag, 3 speed 5831 Spicer, Dana 80 axle 4.11:1.
19.5 Vision Wheels / 225/70r/19.5 tires Always
feels like
Nightrainhauling is offline
post #10 of 16 (permalink) Old 04-12-2011, 12:57 AM
Jossi's Avatar
Yep, darn fine piece of equipment! You gotta gear for every situation!
"----If it ain't loud, lowered, long, and flatblack....an ain't belchin' black smoke...an don't have at least 1 Turbo....it ain't about S***!"-SCREAMIN' METAL
Jossi is offline
post #11 of 16 (permalink) Old 04-12-2011, 01:17 AM
DodgeMech's Avatar
nope they make overdrive units too...just recently one of those two(gv or usg) stopped makin em...
-CJ
02 Taco Prerunner
06 Jetta TDI
formerly, a couple of dodge diesels...again someday perhaps
DodgeMech is offline
post #12 of 16 (permalink) Old 04-13-2011, 07:59 AM Thread Starter
1992rm250's Avatar
what other companys are out there ? and any other options /
The Following User Says Thank You to 1992rm250 For This Useful Post:
2Stacks (02-02-2014)
