Bad lift pump symptoms - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 03-16-2011, 10:39 PM Thread Starter
Sweatin to the oldies
thechoochlyman's Avatar
iTrader Score: 7 reviews
I've just been wondering what the tell-tale signs are for a dying lift pump. I know that is the lift pump goes out in a 24v, if it's not replaced immediately it can cause the main injection pump to fail. Is the VE/P-Pump the same way or will the engine just suffer a noticeable power loss until the lift pump is replaced?
One smkin' fast '89 dually that roalles coalle until your eyes bleed.
1997 Passat TDI with lots of cool swag
thechoochlyman is offline
post #2 of 9 (permalink) Old 03-17-2011, 02:26 AM
91'_250C's Avatar
One way to tell is that there is a weep hole on the lift pump. If there is fuel running down the side of your block and it is coming from the weep hole replace it. That means that the diaphram in the pump has ruptured. And when my pump died I drove back and forth from Montana to Washington 4 times before I could replace it and the only thing that suffered was power loss my pump seems to be just fine.
2011 Ram 3500, G56 trans, PPEI EFI Live, South Bend DD3250, 4" exhaust, Air Dog fuel system, other fun stuff.
91'_250C is offline
post #3 of 9 (permalink) Old 03-17-2011, 02:51 AM
i drove around for a month with a bad lift pump and one day i went to start it and my truck wouldnt run at all so i went and took one off another motor i had laying around and it runs perfectly fine and the thing with the 24vs is that there electric and they will burn up fast thats why alot of guys have fuel pressure guages in there trucks with the 24vs... but my pump works just fine no problems at all
78 dodge power wagon 4x4 cummins swap, full fuel screw turned up, denny t fuel pin, smoke srew cranked, k&n custom intake, making 28 lbs of boost
diesel brad is offline
The Following User Says Thank You to diesel brad For This Useful Post:
cheap12v (04-14-2015)
post #4 of 9 (permalink) Old 03-17-2011, 09:58 AM
1ST GEN MODERATOR
Philip's Avatar
iTrader Score: 12 reviews
The VE will draw fuel on its own. There are arg apps where the VE has no lift pump.
Some of the signs of a dying lift pump. You see boost dropping for no reason. You notice the engine kind of laying down in the upper RPM ranges. You can't prime a new fuel filter on change out.
I lost a lift pump in Okla a few years ago. I drove back to Indiana with the bad pump. I couldn't find a pump on Saturday night and I wasn't going to pay Cummins in Tulsa $50 for a call in fee.
2014/93 W350 DRW, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, air ride rear suspension,B&W flatbed
Philip is offline
post #5 of 9 (permalink) Old 03-17-2011, 10:11 AM Thread Starter
Sounds good. I was just worried I might accidentally starve my VE if I found out too late. Thanks guys!
post #6 of 9 (permalink) Old 03-17-2011, 12:36 PM
cornman369's Avatar
now i know im a little late to this party, but this is somthing that ive thought about for awhile now.
my truck seems just not as peppy as i remeber, even with bigger exhuast and intake it just feels slugish, from memory.
the thing that got my attention was when i drained the water out of the fuel filter i reached down to pump it back up and it got firm then no resitace what so ever. ive done this a few times with the same result is that a sign of a weak pump?
mabey i just have a subconscious need to bomb the pump?
ch
92 D250
fuller 13 speed and 3.07 swap in progress
99 24v 2500 sport auto
72 International Harvester 1110 soon to be 3-53Detroit diesel nv4500
cornman369 is offline
post #7 of 9 (permalink) Old 03-17-2011, 01:30 PM
ch
I had the same experience... I figgered the pump was was bad so I replaced it... I went to pump the new pump it and the same damn thing happpened... I could move the lever but there was no resistance...
what I think happens is that the engine always stops in the same place, with the fuel pump eccentric keeping the fuel pump in the 'pumped' position. (so that the hand lever has no function).
I turned over the engine 1/4 turn by hand and then the little lever worked fine. I did not need to replace that pump.
'93 DRW X-Cab A518 Bone stock except for heater grid delete. No black smoke. 287K
93wuntun is offline
post #8 of 9 (permalink) Old 03-17-2011, 02:28 PM Thread Starter
When I just replaced my fuel filter, my hand pump was firm when I used it before I took off the old filter, and I could tell it was trying to pump fuel. When the new filter went on, I pumped it a couple of times then it get firm again (I filled the new filter with Diesel beforehand). I released the bleed valve over the filter, pumped it again, and diesel sprayed out everywhere. So, I guess mine is good for now. haha
post #9 of 9 (permalink) Old 03-19-2011, 11:17 AM
Left out in the cold's Avatar
The two thinks I've noticed with a weak pump in loss of top end and an occasional loss of prime. I have a long steep hill at the end of town I have to climb every morning. Some times I don't quite make it to the top.
Left out in the cold is offline
