Front wheels bearing nut torque spec? - Dodge Cummins Diesel Forum
post #1 of 2 (permalink) Old 02-09-2011, 04:53 PM Thread Starter
Just curious? Changed mine out the other weekend and going to check them again tonight.
Thanks
05 QCSB 4x4 Garmon Stage II, Smarty S06, straight piped
GAJon is offline
post #2 of 2 (permalink) Old 02-10-2011, 11:50 AM
Moderator
9297oldram's Avatar
The FSM for a 92 with Dana 60 says tighten inner lock nut to 50 FT. lbs. then loosen it and retighten to 31-39 FT lbs. while turning hub then back off nut 135-150 degrees to set free play. The outer nut gets torqued 160-205 ft. lbs.
92 D250 parted out
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 4x4 with 92 Cummins zf5
9297oldram is offline
The Following User Says Thank You to 9297oldram For This Useful Post:
GAJon (02-10-2011)
