89-93 PowertrainDiscussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING
I have to replace the throttle position sensor in my D250 about every 30,000 miles, is this a charastic of this truck or is there something else I should do beside replace the TPS, does anyone know wh
y it goes out and what makes it go out. Thanks
Many folks take them apart to clean it and coat the internal working with dialetic. Are you sure it isn't a connetion problem at the TPS?
Many will install a manual switch to "over-ride" the "syetem"
Still, others install the potentiomenter.
This has been discussed for years and seems to be a popular subject for any who have the four speed auto, as the TPS is very much a weak link. If it wasn't, it wouldn't be discussed so much.
Have you tried to adjust it? When I purchased my first truck with the TPS, it was recently replaced and still didn't work. I found that I had to adjust it.
What have you done? 30,000 miles sounds a little short lived.
Do you know how to test it per the OE service manual?
1990 D250/1992 D250 Modified by **Smokehouse Diesel** Ashland, OH
....therefore, my brothers, I want you to know that through Jesus the forgiveness of sins is proclaimed to you. Acts 13:38
scrap the factory tps and put a DNR customs 1st/2nd Generation Dodge OverDrive Kit *91.5-98 12v, I can say that i was amazed how good the kit works, and took me about 20 minutes to install, no more shifting in and out of over drive and you can set speed to were you want over drive to kick in.
The downside is that it will shift into od at that speed regardless of how loaded you are or how steep the grade, or if you're just idling around town. It also won't give you an automatic full throttle downshift into third until you get below the set speed.
Steve g
91 D-250 LE Bone stock so far 590,000 kms and everything working just like the factory intended with no POTS, pans, string, jumper wires or ball point pen springs.
It could be not that it needs replaced, but adjusted. I know that it has been almost a year to the date (Jan. 24 according to my maint. log) that i last adjusted mine and i have to do it again.
1993 W250; 60HP injectors, 366 Spring, Icebox Intake w/ S&B Filter, Str8 Piped 4" Exhaust, AT w/ First-Stage Billet Converter, and 4.10 Gears. Isspro Gauges: Pyro, Tach, Boost, Tranny Temp. And of course, High-Beams on the floor!
