Compression for 5.9 6BT engine? - Dodge Cummins Diesel Forum
post #1 of 5 (permalink) Old 04-09-2006, 06:26 AM Thread Starter
What is the comrpession suppose to be for a good Cummins 5.9 6BT engine? I've found the compression RATIO (17:1) but can't find the target pressure I should read on the gauge. I'm getting 470-480 pounds in 5 cylinders and 425 in #3, dry. A wet compression test showed 510 in all six cylinders.
I'm getting ready to replace the lower end bearings to bring my oil pressure up. Should I do a ring job while I'm in there?
Aloha from Kona, Hawaii. Captain Dean Towle
1991.5 Dodge Ram W250 CTD w/IC 4x4 5-speed Hummer wheels & tires
Captain Dean is offline
post #2 of 5 (permalink) Old 04-09-2006, 11:12 AM
Your numbers sound very good.
Bad idea to do a wet compression test on a diesel as the oil can ignite and start the engine.
The pressure can then go so high that the gauge will actually blow up.
Cummins doesn't usually use a compression test to determine engine condition but rather a blowby pressure test.
Bill
'95 2500 4wd auto
'95 3500 5 speed heavy hauler
Stock for one day
illflem is offline
post #3 of 5 (permalink) Old 04-09-2006, 03:04 PM Thread Starter
Thanks for the information Bill. The thought of ignition did cross my mind but I dismissed it because I was using synthetic oil. I never did consider igintion causing the gauge to explode.
Are there any crankcase pressure specifications to help determine a good engine from a bad one? The blow-by method explains why I couldn't find any information about cylinder compression.
post #4 of 5 (permalink) Old 04-09-2006, 03:16 PM
You need a blowby tool.
The Cummins blowby orifice tool is simply a tee with one .221" (15/64-in) outlet. Connect one end of the tee to the end of the blowby tube. Put a manometer on last tee outlet. That is your blowby tool. They sell them at the Cummins, but I have made my own plenty of times, less than $10. A simple manometer can be made by looping into a 'U' 6 feet of clear tubing with water in it half way. Measure how high the water level rises with a tape measure, multiply it by 2, convert it to LPMs.
Rough conversion is 1"= 27 lpm, add 3 lpm for each one inch (1/2'' of rise in the tube) of water
The reason for multiplying by 2 is that inches of water equals the water rise in the open end of the tube plus the inches the water is pushed down on the engine side of the water tube. For simplicity my numbers below are the measurement of rise only.
Cummins new 5.9 engine numbers are:
63 liters per minute(2.5" water rise) @ 2200rpm,
76 L/Min (3.5" rise) @ 2500rpm
85 L/Min (4.5" rise) @ 2800rpm.
Worn engine that needs rebuilding are roughly double i.e.
126 L/Min(10.5"rise) @ 2200rpm
152 L/Min(14.5"rise) @ 2500rpm
170 L/Min(17"rise) @ 2800 rpm
Beside indicating a compression problem the valves could also be out of adjustment.
Another way (mine), same idea, is to block the blowby tube with a 1/2'' pipe nipple with a cap that has a 15/64 hole drilled in it. Use 3/8'' id looped clear tubing with water in it slipped over the oil dipstick tube. Other tubing end remains open. Use a sharp tipped felt marker to mark the water level with the engine off, have a helper start an already warmed up engine and run the rpms up to 2.2, 2.5 & 2.8k rpms. Mark each water level with the pen, measure the distance from engine off mark then multiply each by 2.
This is all very simple to do, just hard to explain with words.
Bill
'95 2500 4wd auto
Stock for one day
illflem is offline
post #5 of 5 (permalink) Old 04-10-2006, 02:30 AM
Paccool's Avatar
Capt. Dean,
What is the oil presure reading? How many miles on the engine?
Put a pressure gauge in the extra port at the top of the oil filter housing before replacing the bottom end. The gauge is the quickest just to check the pressure and the reading of the dash unit. If you have good pressure there, try replacing the sending unit.The sending unit might be reading wrong. My pressure dropped to zero then came back up slowly and the problem was the sending unit (thank God!)
Stan
93 D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust, modified tranny, EGT/boost/tranny/tach gauges, TPS removed, a little chrome under the hood. Mag-Hitec tranny and diff. covers. Rear sway bar. Line-x bed liner, after market seats. Single stage Water/Meth system installed. Oversized intercooler w/3" IC lines.
05 Chevy 2500 HDcrew cab 4x4, Duramax W/Allison, 17" Hummer wheels w/285-70-17 BFG's, Banks intake, ported turbo mouthpiece. Predator programmer, Autometer EGT and boost gauges.
Paccool is offline
