Help !! oil pressure drops when idling - Dodge Cummins Diesel Forum
post #1 of 8 (permalink) Old 10-18-2010, 07:42 PM Thread Starter
rebeldodge1993's Avatar
alright I need advice my oil pressure drops off the gauge when my truck idles and when I shift but it builds back up when I get up in higher rpms ?? I changed the oil pressure switch out about a year ago and has lifetime warranty would this be bad connection in switch or would this be oil pump cause oil pump is mechanical and either it works or it shouldn't right ? any ideas
1993 d/w250 LE 5 speed & 4x4 conversion- s300, 4in custom exhaust, M&H timing spacer, BHAF, Denny T Pump top, Ptroke Coolertubz, 99 Pstroke intercooler, 366 spring, SDX 5x14's (140's) airdog 150gph, 3 piece manifold, pump tuned up and KDP tabbed
rebeldodge1993 is offline
post #2 of 8 (permalink) Old 10-18-2010, 10:23 PM
If it were my truck I would plumb a mechanical gauge under the hood to see what its actually reading first, then if it was that low I would do an oil pump and hope that fixed it. Not a problem you really want to mess around with...
Edit: Yes oil pumps are mechanical, when they are worn they produce low oil pressure.
Confused_Pete is offline
post #3 of 8 (permalink) Old 10-19-2010, 07:20 AM
what he said!
Get a gage with numbers on it so you can see what it really is; the gage pin sitting on 'L' isn't going to tell you anything useful. On the oil pump swap, IIRC it is easy to do with the timing cover off like you were going to tab the KDP and tighten the hidden bolts.
cheers,
Douglas
1990 D250, NV5600, 16cm housing, PAC brake, TST Kit KDP tab, Powr-Lok'd 3.07, HX35....IC soon
1991 D250, 16cm housing
Douglas2 is offline
post #4 of 8 (permalink) Old 10-19-2010, 02:28 PM Thread Starter
well I am gonna pick up a oil pressure guage today and the pressure sending unit I wanna make good and sure my baby has oil to the top end and turbo but I have been looking and the original sender is a little loose and it spins ? but this morning it worked fine until I got to work I pushed the clutch in and it dropped to zero but the oil light or check engine light don't come on when it drops either
when I broke my last pressure sending unit the oil pressure dropped off the guage and all the lights come on but this time they don't come one it's weird
post #5 of 8 (permalink) Old 10-19-2010, 02:32 PM
SubliminalME's Avatar
When I was playing with my pump I set my idle too low and I'd constantly drop to 0 on the pressure gauge at idle. The gauges are just dummy lights anyhow...but if you've played with the idle, that could be it.
91.5 W250. 518-360 Swap, 12cm housing, Bosch 190s, Keldermann air ride.
SubliminalME is offline
post #6 of 8 (permalink) Old 10-19-2010, 05:22 PM Thread Starter
well this all started yesterday on my way home from work and I haven't done any adjustments at all and I have my pump idled up from stock cause it builds boost quicker but I'm gonna figure it out today and I'll post my findings
post #7 of 8 (permalink) Old 10-19-2010, 11:10 PM
1ST GEN MODERATOR
Philip's Avatar
iTrader Score: 12 reviews
After market or OEM item???
Does the low oil pressure light come on also???
2014/93 W350 DRW, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, air ride rear suspension,B&W flatbed
Philip is offline
post #8 of 8 (permalink) Old 10-20-2010, 12:04 AM Thread Starter
no none of the lights come on at all when it drops it just pegs zero and builds back up after but I swapped it with one from napa and it seams to work good and it's back to normal takes a couple seconds to build up when I start it like usual I got an oil pressure guage in the passenger seat that I haven't installed but the dash is reading fine but i think it was just a junk part from oreillys last time... i don't really use much dealer items cause the nearest dealership is in Houston about an hour away and i hate Houston traffic and I'm pretty sure they hate me to for my smokeshows I leave them lol
