1993 no overdrive - Dodge Cummins Diesel Forum
post #1 of 21 (permalink) Old 10-09-2010, 11:19 AM Thread Starter
1993 no overdrive
Just purchased a 1993 Dodge 2wd automatic truck. The cruise control and overdrive dont seem to be working. Iv tested the TPS which is good, adjusted my TV cable properly and checked for 12v at the 2 wire plug on the side of the transmission that sticks straight up, is that the correct plug to check? Im going to run a wire off the ground side of that plug on a switch next to see if I can get overdrive to work. Any ideas on what to check next? I dont want to use a potentiometer.
Thanks
Confused_Pete is offline
post #2 of 21 (permalink) Old 10-10-2010, 04:23 PM Thread Starter
So I wired a ground on a switch to the plug on the transmission and it shifts into overdrive when its turned on. Can I keep it on a switch for the time being while I figure out whats wrong without damaging the transmission?
post #3 of 21 (permalink) Old 10-10-2010, 08:57 PM
Honestly, that's what I plan to do. Every time I hit a bump on the highway it kicks out of OD. Could be a lot of things including the ECU.
I'm thinking of running the switch to my non-functioning cruise rocker on the steering wheel.
GumbyIL is offline
post #4 of 21 (permalink) Old 10-12-2010, 08:34 PM
CUMMINS959's Avatar
Ive heard from a few people that the throttle position sensor is what actually allows the trans to go into od on these first gens. if they go bad the truck wont hit od. im not 100 percent sure but its worth a shot before u tear the tranny apart.
01 qcsb auto. banks 4 inch strait. quad adr. full s& b. air dog 150. PROtorque tranny.
93 sclb.....ROUGH... work in progress
CUMMINS959 is offline
post #5 of 21 (permalink) Old 10-12-2010, 10:14 PM
There are a lot of things that make the A518 not go into OD. The trans coolant temp sensor, the brake light switch, the ECU, the TPS, the OD solenoid, a number of grounds.
To wire the OD to a switch doesn't require opening the trans at all. Not even dropping the pan.
GumbyIL is offline
post #6 of 21 (permalink) Old 10-12-2010, 11:05 PM Thread Starter
Did you even read what I posted?
Spoke to a transmission guy and he advised me not to have over drive wired to a switch. If the transmission tries to down shift, example making a hard sudden brake app, it might not like that too much. He explained it in more technical terms then that as to what happens but I got the jist of it. Looking at temp sensors next.
post #7 of 21 (permalink) Old 10-14-2010, 03:54 AM
theres 2 sensors on these trucks, and they both suck ... they should both be removed and jumpered due to the fact that they thought back when vanilla ice was cool, that keeping the tranny out of OD when your coolant is under 60 degrees saved your transmission...
check on the side of your block under the head, drivers side, its called the coolant thermal switch, they go bad... almost always...
check in this order for the cheapest easiest way to fix your trucks OD
run the ground to the non 12 volt on the 2 wire as you described in your post.. and make sure your trans clicks into OD, if it does follow the following steps. if it dosnt then your OD solenoid is toast.
check TPS, should be at .8 - 1.0 volts on the middle wire. should go up around 4.0 at WOT, mines at .6 volts, eventhough the manual says .8-1.0 you have to play with the TPS to figure out your true setting..
check the coolant thermal switch by unplugging it and jumping it with a wire.
check the trans overheat switch on the hot port out of the transmission, cant miss it, 2 orange wires... jumper that also
now go drive the truck, see if it shifts good, if it does, reverse the order one by one until you find the culprit... imo, jumper them and get rid of the trans overheat switch and put in a trans gauge... that helps a ton...
if none of those worked, your PCM is toast... i read they are being rebuilt for a couple hundred... imo, if you dont have the cash, then run the manual switch for your OD, it will hurt your tranny only if its getting hot and not shifting into 3rd... your trans will shift out of OD under a certain speed, and go into OD as soon as 1-3 seconds after you shift into 3rd if you leave it on all the time.. ( my switch broke and limped home ) but drove fine...
any more questions just ask
91.5 D350 Flatbed Dually, HE351CW, Built 46RH, 4.10 Gears, Denny T Pin, Timing Spacer, 3200 Spring, BHAF, 4" Exhaust, Glowshift 3n1, Borgeson Extreme Steering Shaft, 6K HID, K3LA Train Horn, 12000 Pound Winch.
Brucetafer is offline
The Following 3 Users Say Thank You to Brucetafer For This Useful Post:
Dieselluvr (11-02-2012), lbcdiesel (03-30-2015), meb4byn (05-08-2013)
post #8 of 21 (permalink) Old 10-29-2011, 12:08 PM
moondoggy's Avatar
Dodge Cummins 1993 overdrive
When setting up the TPS check the voltage slowly all the way through the accelerator pedal travel. If voltage does not smoothly increase, but jumps, even out of acceptable range, TPS is bad.
moondoggy is offline
post #9 of 21 (permalink) Old 06-09-2012, 09:18 AM
Thunder5.9's Avatar
Thanks
where is this plug located? drivers or passenger side, and towards the front or rear? i'm having the same problems with my truck and i'm gonna try this first. thanks
Thunder5.9 is offline
post #10 of 21 (permalink) Old 11-02-2012, 12:19 AM
Thanks Brucetafer! I was having the problem with my overdrive kicking on and off and found out it was the coolant thermal switch near the top, back of the drivers side block. SWEET!
93 W250 LE Club Cab, AT, 3.91 Sure Grip, DE 4"exh, Cooler Tubz, BHAF, Gauges, POD's, M&H timing spacer, Gillette Diesel fuel pin & 60cm compressor, Star wheel turned, Power screw maxed, KDP and case bolts fixed, WVO conversion, Skyjacker, Rancho's
Dieselluvr is offline
post #11 of 21 (permalink) Old 11-04-2012, 08:38 PM
Quick question: is the temp sensor on the block the same one that reads temp for the gauge? As in: if i replace the sensor that is listed on rockauto.com as the temperature sensor for my truck will that same sensor be used by my trans?
1991.5 D250 6BT
2016 6.7 3500 4x4 68rfe
MYdadCANbeatupYOURdad is offline
post #12 of 21 (permalink) Old 11-04-2012, 09:44 PM
Moderator
9297oldram's Avatar
No it's not the same it's tucked under the cyl. head right behind the fuel filter in the side of the block.
92 D250 parted out
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 4x4 with 92 Cummins zf5
9297oldram is offline
