Solid Motor Mounts? - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 09-28-2010, 07:42 PM Thread Starter
90dodgectd's Avatar
Solid Motor Mounts?
Hey guys just bought a 1990 D250 Cummins 5-speed and it needed motor mounts and the trans mount wasnt even bolted in. Well I fixed that and put new motor mounts in it and the motor and shifter still torque up pretty bad. It must be a 2wd thing cause my other 90 is a 4wd and the motor nor the shifter move. Just wondering what you 2wd guys do to fix this problem and if there are any solid motor mounts i can put in. Thanks.
1990 Dodge W250 CTD G360 - BHAF,Str8 Piped 4in Duals,HTT 60mm Housing, 16cm Housing,366,Pump Maxed,Timing Bumped,DennyT Pin
1990 Dodge LE D250 CTD G360 - M&H Timing Spacer, 366, 4in side dump
90dodgectd is offline
post #2 of 4 (permalink) Old 10-03-2010, 11:13 AM
Left out in the cold's Avatar
The Cummins rattles the truck enough with standard mounts, solids would be a very bad idea.
Dodge motor mounts have an interlocking plate to keep them together if the rubber brakes. Look at them real close, if the don't look broke, jack up the engine and see if they separate.
Left out in the cold is offline
post #3 of 4 (permalink) Old 10-04-2010, 06:07 AM Thread Starter
90dodgectd's Avatar
I just put brand new motor mounts on the truck and it still torques up. Im just gonna put a torque chain on it until i can save up for poly mounts.
post #4 of 4 (permalink) Old 10-04-2010, 07:51 PM
Just picked these up for my 1st gen swap
polyurethane Dodge diesel engine mount
feel free to delete if this is considered advertising
I've known the guy for years
Very high quality products
Can't wait to try them out
'85 GLH Omni 10.65 @ 129
'95 3500 4x4 12v NV4500 Dually
Dentside Diesel '92 12v Cummins A-518 swapped '78 F-250
"Top Fuel" Bender is offline
