How to Adjust Idle RPM? - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 06-27-2010, 10:56 PM   #1 (permalink)
ARbowhunter7's Avatar
First, my truck idles MUCH too high. I don't have a tach yet, but it sounds REALLY high compared to other trucks. I am also seeing other tendencies that would indicate a higher idle than normal. First, when I crank it up, even when cold, it fires up faster than any truck I've ever owned...less than half a turn of the starter and it's running. Seems like this could be a sign, also, there is a big jolt/shock when switching into gear from Park or Neutral.
I have read about a screw to adjust idle, and I imagine I could find out where it is, but I'm really looking for advice from you guys about adjusting it. How much adjustment drops 100 rpm, etc...and tips or pointers you could give me would be great. Thanks.
1998 12V 3500 4x4...You know what it is
ARbowhunter7 is offline   Reply With Quote
Old 06-28-2010, 10:41 AM   #2 (permalink)
Left out in the cold's Avatar
A fast start is the sign of a good engine. Looking at the injection pump from the finder side you see a long screw with a lock nut that the throttle arm hits at full throttle. That is the full throttle stop. On the back side (engine side) of the pump is an identical screw, that is the idle screw. Loosen the lock nut and back the screw out until you reach 750RPM. Then lock the nut.
91.5 W250 4X4 5spd 3.07s HTB2 62/13SS DE 4" exhaust M&H M2 and timing device BHAF DAP 7X.010 tuned pump pre/ post EGT
92 W250 Xcab HD auto 3.54 modded H1C turned fuel pin
Left out in the cold is offline   Reply With Quote
The Following User Says Thank You to Left out in the cold For This Useful Post:
Cummins250 (03-06-2011)
Old 06-29-2010, 04:57 PM   #3 (permalink)
powerbrake's Avatar
what you said, yes indeed. unless the dern screw want to be a pain. mine was so i took a dremmel tool and started grinding away at the end of the screw until i got the rpm i wanted
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro.
God Bless Our Country and Damn The Goverment
powerbrake is offline   Reply With Quote
Old 06-29-2010, 05:40 PM   #4 (permalink)
Your not fooling anyone. We know you and power tools.
Old 06-29-2010, 05:42 PM   #5 (permalink)
mine was easy to adjust. took about 5 min to find 700rpm. but it wasn't hard at all.
had a 1992 w350 non-dually, smoke screw fully turned, starwheel dropped to the bottom, bully dog fuel pin, power screw fully turned, 100hp injectors, 4600 gov, HX-40, No WasteGate, 6" stacks, 3" lift, K&N, and 817 Tranny(blew turbo and exploded)
CumminsT92 is offline   Reply With Quote
Old 06-29-2010, 05:52 PM   #6 (permalink)
powerbrake's Avatar
more power
Old 07-04-2010, 11:50 PM   #7 (permalink)
I used my pliers and bent the tab just a hair. worked perfect.
1994 Chevrolet 1 ton flatbed, with 12 valve cummins. nv4500, advanced adapters bellhousing. oversized flywheel & 13" clutch. Pillar mounted Isspro pyro and boost gauges. 3" straight exhaust.
plcnut is offline   Reply With Quote
Old 07-05-2010, 10:59 AM   #8 (permalink)
tiny2085's Avatar
I also don't have a tach, an after adjusting my power screw the truck idled high enough to be a pain at stop lights. I just used my ear, listened for a smooth quite idle, made sure the oil pressure was still good and called it a day. Make sure and put it in drive after you adjust it to make sure it's still smooth under a load with the A/C on.
05' 3500 dually 4X4 QC 6 speed! - In for heart surgery !
93' cc srw 2wd - 60mm /sticks, 366 /pump tweaks
92 2WD SWB in the making...
tiny2085 is offline   Reply With Quote
Old 03-06-2011, 11:35 AM   #9 (permalink)
Cummins250's Avatar
is there anyway you guys could post a pic i must be blind b/c im not seein it thanks to all !
Cummins250 is offline   Reply With Quote
Old 03-06-2011, 12:02 PM   #10 (permalink)
Moderator
9297oldram's Avatar
Look at the opposite end of the arm that the throttle linkage fastens to, it's just a threaded bolt with a lock nut that's hard to get to.
92 D250 custom made bed, 190 inj., 16cm , electric cooling fan, 2nd gen air horn, 5spd., Dana 61 3.31 gears, 1 stage W/M set up
97 2500 4X4 auto DDP 40 HP injectors, no 8 fuel plate, homemade 3" intake horn, BD converter, BHAF, electric cooling fan
9297oldram is offline   Reply With Quote
The Following User Says Thank You to 9297oldram For This Useful Post:
Old 03-06-2011, 09:43 PM   #11 (permalink)
Cummins250's Avatar
oh duh right in front of me haha thanks guys appreciate it !!
