How to prime? - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 04-21-2010, 09:43 PM Thread Starter
TheFNG21's Avatar
How to prime?
Changed my fuel filter but can't find the primer so now she won't run ha. Any help?
08 qclb 4x4 daily driver. Manual. Deletes. Autocal by Kory. Leveled out. 109k miles as of now
TheFNG21 is offline
post #2 of 7 (permalink) Old 04-21-2010, 09:54 PM
powerbrake's Avatar
there is a lever on the firewall side of the lift pump. if it's not there then you'll need a new pump or maybe it's time to upgrade to an electric pump to keep up with the 450 hp your after
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro.
God Bless Our Country and Damn The Goverment
powerbrake is offline
post #3 of 7 (permalink) Old 04-21-2010, 10:03 PM
5.9fan's Avatar
Bleeding the fuel system
this should help
2014 CCLB 4x4 Tradesman. 5th wheel prep, upfitter switches, LSD, plow prep, on board air, amp bedstep
Its quiet... too quiet...
5.9fan is offline
post #4 of 7 (permalink) Old 04-21-2010, 10:10 PM Thread Starter
TheFNG21's Avatar
Ok so I primed the pump but now when I turn the truck on it's pours fuel out the bottom of the filter through the rubber hose
TheFNG21 is offline
post #5 of 7 (permalink) Old 04-21-2010, 10:46 PM Thread Starter
TheFNG21's Avatar
We are all good now. I think I primed too much maybe. Trucks runs way better I'm pretty shocked actually. And can someone tell me how changig fuel filters made my oil pressure reading stable? I replaced the sending unit weeks ago and my pressure would just rise to normal then randomly fall to zero and never trigger the light
TheFNG21 is offline
post #6 of 7 (permalink) Old 04-22-2010, 07:38 PM
5.9fan's Avatar
the pressure sender wires probably have a small short somewhere (very very common) and you probably hit them while changing the filter.
5.9fan is offline
post #7 of 7 (permalink) Old 04-22-2010, 08:44 PM Thread Starter
TheFNG21's Avatar
Thanks. I figured it was just a short but wasn't 100%
TheFNG21 is offline
