Timing Gear Housing Gasket - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 04-11-2010, 08:44 PM Thread Starter
Diesel_smoke_addict's Avatar
Well today I started out to replace my water pump and while I was in there I figured I'd fix the KDP to and found out why my truck is leaking oil. The person in there before me didn't put the gasket on the back of the timing gear housing on right (Why my truck is leaking oil) or the fix KDP. I've got everything taken off up to the timing gear housing cover. I am wondering how difficult it would be to get to that gasket on the back of the housing. I know you have to take the gears off and then take the bolts off the housing to get to the gasket then put the bolts back in and line them back up but is it a science or could I just make marks on the gears and stick em' all back the way they came out?? I do have a book that will tell me how to get the housing, gears, ect. off and back on . . . but it's not very thorough and I didn't know if any of you guys would know if there is anything with more in depth instructions or if anyone has done this before??
93 W250, Plenty of headlight fluid, Some muffler bearings, Gauges and a 4in lift with 37's. 335HP and 622FT-LBS. *16.8 secs @ 79mph 1/4mile* *263.01ft Working Stock*
Diesel_smoke_addict is offline
post #2 of 14 (permalink) Old 04-11-2010, 08:58 PM
cornman369's Avatar
dont know, wish i did thow this was exact plan my water pump started seeping on sat
but i figured it would be a good time to do kdp also
my understanding is remove belt, rad, fan, then bolts on timing cover, tighten, new gasket+front seal replace timing cover then water pump, replace fan, rad, belt.
also replace water
in the same boat as you so basicly
subscribed
ch
92 D250
fuller 13 speed and 3.07 swap in progress
99 24v 2500 sport auto
72 International Harvester 1110 soon to be 3-53Detroit diesel nv4500
cornman369 is offline
post #3 of 14 (permalink) Old 04-11-2010, 09:28 PM
Do you have to pull the harmonic balancer?
'93 W250 HD, 5 speed, 4.10's, 3200 rpm spring, 4" exhaust, 195,000 miles, 90 gallon fuel tank
Lithgow is offline
post #4 of 14 (permalink) Old 04-11-2010, 10:01 PM Thread Starter
yes you do
post #5 of 14 (permalink) Old 04-12-2010, 12:48 AM
Dieselpolluter's Avatar
You can't just pull the gears off. The cam gear is pressed on so you would have to pull the whole cam out.
92 W250 CREW CAB CR (IN PROCESS)
2005 QCSB
Dieselpolluter is offline
post #6 of 14 (permalink) Old 04-12-2010, 01:05 AM
bulldog77's Avatar
iTrader Score: 5 reviews
There is somewhere on hear that you can remove the cam gear and heat it with a toaster oven to reinstall. Guess dodge dealers are usin heat to put them back on and not pullin the cams anymore.
None of your damn buisness of whats done to my truck.
bulldog77 is offline
post #7 of 14 (permalink) Old 04-12-2010, 06:56 AM
First Generation Moderator
Greenleaf's Avatar
There is no gasket between the aluminum gear case and the front of the block? Is that right? Or maybe it is torn etc?
You really want to pull the cam. That is what the performance shops do as they prefer to not mess around with the liability of a cracked cam gear. It isn't a bad job if you know what to expect.
1990 D250/1992 D250 Modified by **Smokehouse Diesel** Ashland, OH
....therefore, my brothers, I want you to know that through Jesus the forgiveness of sins is proclaimed to you. Acts 13:38
Greenleaf is offline
post #8 of 14 (permalink) Old 04-12-2010, 03:56 PM
Yeah they try to heat them in place and pull them but alot of times they end up pulling the cam anyway cause you need to heat the gear to atleast 350 and it needs to be gradual heat so it won't crack.
2005 QCSB
post #9 of 14 (permalink) Old 04-12-2010, 10:08 PM Thread Starter
There is a gasket but it's not very well placed
I'm just gona put some special kind of caulking that my dad is going to get and put it around the gasket and call it good because I don't want to take it off. . .
post #10 of 14 (permalink) Old 04-14-2010, 07:01 PM
cornman369's Avatar
any words of advice for removing the bolts on the vibration dampener? {harmonic balancer}
i cant get them to come loose and have no way to keep the motor from rolling back, impact?
ch
92 D250
post #11 of 14 (permalink) Old 04-15-2010, 12:01 AM Thread Starter
If you have the fan and radiator off then the Impact might work if it has enough torque . . . but me and my dad got the VD off with a pry bar and an old serpentine belt. You could remove the dust cover and that might give you enough room to be able to hold onto the VD and get the bolts off
post #12 of 14 (permalink) Old 04-15-2010, 09:19 AM
Greenleaf's Avatar
The method is to remove fan clutch assy. The snap-on tool or a open ended wrech and a pretty good sized hammer works just as well. Then you'll need some tools. 15mm six point in 1/2 inch drive regular depth socket. Then an adapter from 3/4 inch drive to the 1/2. Then a 3/4 inch drive breaker bar. Then that pretty good hammer again.
Very easily done and works quite well. Knock 'em loose and turn them out. I have performed siad KDP tab in many a truck and the above is cake work. You will NOT have to hold the crank from turning.
The Following User Says Thank You to Greenleaf For This Useful Post:
cornman369 (04-15-2010)
