stock gear ratio's for 1991 w350? - Dodge Cummins Diesel Forum
post #1 of 10 (permalink) Old 03-23-2010, 06:06 PM Thread Starter
I have a 1991 W350 picked out to buy, but just want a little more information.
What gear ratio's came in this type of truck? It isn't a dually, just singles on the back.
Also, it is an automatic. Are these automatics 3 speeds or do they have an overdrive?
Lastly, is there a preferred combination in these trucks in terms of reliability? For example transmission types/ gear ratios/ transfer cases?
Sorry for the ignorant questions and thanks in advance for any info. Just want to learn as much as possible about the different drivetrain combos in this year.
Thanks,
Clark
scjfly is offline
post #2 of 10 (permalink) Old 03-24-2010, 02:10 PM
Brandonsmokincummins's Avatar
Check the axle tag i think it might have 4.10 gears
91 W250 5 speed Built trans lots of fuel lots of air south bend clutch denny T stage II 5 inch exhaust traction bars
OHIO COAL ROLLERS
Brandonsmokincummins is offline
post #3 of 10 (permalink) Old 03-24-2010, 08:06 PM
5.9fan's Avatar
a stock automatic 91 will have 3:07s in the rear. It is (if stock) a torqueflite 727 which is non overdrive. the lower gears IE 3:54s and 4:10s were only found in trucks with manual tranmissions.
IMO the best setup would be a standard trans with 3:54s
2014 CCLB 4x4 Tradesman. 5th wheel prep, upfitter switches, LSD, plow prep, on board air, amp bedstep
Its quiet... too quiet...
5.9fan is offline
post #4 of 10 (permalink) Old 03-24-2010, 11:37 PM
91hoss's Avatar
my automatic 1991 w250 has 3.50 gears and overdrive stock. But mine is a 91.5 (intercooled) if yours is the earlier 91 (non-intercooled) it most likely will not have overdrive.
91.5 W250, 35x12.50 Toyos, 2.5" Skyjacker Lift, Pump Turned UP
1995 2500 4x4, NV4500, #10 plate slid forward, boost power fitting, 3GSK, Z-series pillar mount gauges
91hoss is offline
post #5 of 10 (permalink) Old 03-25-2010, 12:31 AM
jonny1stgen's Avatar
89-91 have a non intercooled engine with a 3 speed with 307 gears. the 91.5-93 have a intercooler and overdrive. not sure about gears on the later years you will have to check the tag
13 2500 Tradesman RCLB 4x4 68rfe 3.42
90 W250 RCLB 727 P7100 s300
04.5 2500 4x4 RCLB 6sp cts SOLD
jonny1stgen is offline
post #6 of 10 (permalink) Old 03-25-2010, 12:37 AM
old_school_ctd's Avatar
205 transfer case is what it will have and they are pretty darn tough in my opinion
1990 w250 4x4 lots of pump work, 35/40 turbo, fully built tranny, gauges, 6in lift, 5in stack.
old_school_ctd is offline
post #7 of 10 (permalink) Old 03-25-2010, 02:25 AM
peobryant's Avatar
Non Intercooled ratios:
Auto: 3.07 (727 3spd auto)
Manual: 3.54 or 4.10 (5spd Getrag)
Intercooled ratios:
Auto: 3.54 or 4.10 (518 3spd with overdrive auto)
I've also read that you could order certain intercooled trucks (it may have been only '93) with 3.07 gears. Not 100% on that.
Parker
'91.5 D350, 2wd Dually
'10 Jetta TDI, 6 Speed Manual
peobryant is offline
The Following User Says Thank You to peobryant For This Useful Post:
irhunter (12-03-2011)
post #8 of 10 (permalink) Old 03-25-2010, 02:19 PM
Old 'n Rusty's Avatar
If your options sticker is still there on your hood, inside the engine compartment, it should spell out the gearing your truck was delivered with. Mine had 4:10 gearing which was an option for the getrag.
91 (08-90) D250
5sp 2wd 511k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'er
R60/7, Volvo 245 GL 320 k km's, f150 4x4 5 spd, MPG's are in Imp gal's
Old 'n Rusty is offline
post #9 of 10 (permalink) Old 12-08-2013, 01:25 PM
Does it matter whether the 727 was 2wd or 4wd?
buzzin06 is offline
post #10 of 10 (permalink) Old 12-08-2013, 03:21 PM
Moderator
9297oldram's Avatar
You need to know if it is intercooled or non intercooled. 2wd or 4wd doesn't matter it went by auto or manual trans.
But a 20 year old truck could have had a gear swap sometime in it's lifetime so it's better to pull the cover off and check the teeth count.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 SC zf5, 4x4, SAS, 92 Cummins, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod, WM, wh1c hybrid 60/64/18.5
9297oldram is online now
