- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
| 89-93 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
Oil Capacity??
I am getting ready to do my first oil change on my 12v and since I dont have the manual or anything I just want to be sure I put the correct amount of oil in it, including the filter.
2002 6 speed HO, Edge Juice with attitude, Raptor 150, 200hp JL Machine injectors, AFE Intake, FB 5" straight pipe, SB DD 3250, and other goodies!!!!! 1996 12 valve 5 speed, fuel plate, 8" CAT Stack, 100 hp injectors, 4K's etc....
#2 (permalink) |
Three gallons plus one quart.
Sarah McLachlan fact #10: Sarah McLachlan killed Paul McCartney. |
| The Following User Says Thank You to Begle1 For This Useful Post: | Nickscott89 (03-11-2010) |
#3 (permalink) |
![]() Join Date: May 2009
92 W250. Cadet Flatbed with LEDs. Built 518. Pro torque HD converter. gauges. Transmission potentiometer. HX35. 5' aussies. custom ams oil dry filter intake. pump tweaked. ground pin. maxxis bighorns. almost 300k miles. 96 2500. Pretty much stock. ![]() Last edited by Diesel_Addiction; 03-11-2010 at 11:54 AM. |
| The Following 2 Users Say Thank You to Diesel_Addiction For This Useful Post: | Nickscott89 (03-11-2010), Ram Fan (03-12-2010) |
#4 (permalink) |
So by the chart it says it holds 12.5 quarts so 13 quarts would be good, I put 13 quarts in my 24v but I wasnt sure that the 12v was the same, I figured it was but I would rather play it safe!!!!
#5 (permalink) |
I just buy 3 gallons, fill the filter, put it on. Dump the rest in the crank case and go for another 5K mi.
DP
93 W250 xcab LE 300K. Built auto, HX35/40-16 turbo, ISSPRO fuel pressure and pyro. Other goodies and updates coming...... |
#6 (permalink) |
definately remember to pre-fill the oil filter.
1993 D350 dually, automatic. starwheel and afc adjusted other rides: 1956 Packard patrician police car. 1955 Packard patrician sedan.
#7 (permalink) |
Why?? I have changed oil in stuff hundreds of times and I dont pre-fill the filters.
#8 (permalink) |
Pre-filling helps prevent dry start-ups, and with a quart to fill up, it's a pretty long dry start.
Now, it has been argued that today's oils are of a high enough quality to make pre-filling unnecessary, and then you add the remote possibility of getting some gunk in the clean side of the filter as you're filling it. To each his own. I put about half a quart in mine, making absolutely sure nothing gets in the clean side of the filter, then screw it on. DP
#9 (permalink) |
Good info!!!! I could see both sides of the argument I suppose but I believe I will be filling mine from now on!!!!
#10 (permalink) |
I always prefill when I can. Some of my big stuff have huge filters on them. Some are close to a gallon. It helps get the oil going sooner. And I always dump 3 gallons in my b's also.
89 dodge 3/4 4x4, A727 ,3.07 gears, factory L S , powerstroke intercooler, S300, stans exaust with stainless tailpipe, fuel power screw turned?, fuel pin turned to deepest, 3 turns smoke screw, 1/2 turn down on starwheel. 93 W250 ex cab, 6X16's, 60 GDS, rag
#12 (permalink) |
it takes extra COOLANT because the autos have a liquid to liquid transmission cooler.
