Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 03-10-2010, 07:27 PM   #1 (permalink)
92hummincummins's Avatar
fuel solenoid
anyone know how to take it out and what size wrench
92 d-250 club cab auto 5inch straight pipe otherwise all stock 145,000k smoke screw turned NEW PAINT
92hummincummins is offline   Reply With Quote
Old 03-10-2010, 07:32 PM   #2 (permalink)
you have to take the AFC housing off like you are putting in a new governor spring... I think its a 17mm, could be wrong on the size, its bee a while since I have taken it off
92 Dodge D250
"If women don't find you handsome, they should at least find you handy."
dovehunter79 is offline   Reply With Quote
Old 03-10-2010, 09:22 PM   #3 (permalink)
CummNgetSum89's Avatar
dont take the governor off and its a 15/16 just get in there its a pian but you can do it !
99 ex cab long box, 4x4, auto, tci torque converter, airdog II 165 and more soon to come
CummNgetSum89 is offline   Reply With Quote
Old 03-11-2010, 12:50 AM   #4 (permalink)
tyler-brown's Avatar
where do you guys reccomend getting one? (sorry to hi-jack... kind of ontopic still?)
'92 cummins,ext cab.Custom 4" Intake,pump rebuild,star wheel bottomed,smoke screw level with nut,power screw tight to collar.HE341 turbo and 4" exhaust.30+lbs of boost at 1200*. Auto to standard swap complete, and 3.55 axle (for sale) to 3.08 swap complete
tyler-brown is offline   Reply With Quote
Old 03-11-2010, 01:13 AM   #5 (permalink)
JBradley500's Avatar
a lot of people cut the top off of the bracket that will get in your way. i unhooked all of the throttle linkage and it probably was a waste of my time. 15/16 is the size i used also.
VW Volkswagen Diesel TDI Injector Pump Nozzle Fuel Filter Glow Plug Gauge Timing Tool Bosch Injection VNT Turbocharger Head Gasket M-TDI MTDI Golf Jetta 1.6 1.9 the cheapest place to buy them i believe.
you must have a lot of pressure in the pump. to reduce that you can turn back your full power screw, put in larger injectors or just take out the plunger and spring out of your current solenoid and hook a choke cable to the manual shut off on the side of the pump to shut the engine off.
92 W250(Getrag)- S362/65/12 Turbo, 8x.011" Injectors, Denny T, 366 Spring, Piston Pump, SBC OFE Clutch, 4" Exhaust, M&H Timing Spacer, BHAF.
JBradley500 is online now   Reply With Quote
Old 03-11-2010, 12:54 PM   #6 (permalink)
alright thanks guys i'll give her a try if the rain dosent ruin my plans
Powered by vBulletin® Version 3.8.5
