- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
| 89-93 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#2 (permalink) |
Den - Dodge CTD 1st Gen - VE Governor Spring Install
2 things.. have metric ball allen wrenches and know exactly where the throttle linkage is supposed to be when you take it off of the throttle shaft in the pump. thats about all youll need to know to get the job done, its all i had and it went real smooth.
92 W250(Getrag)- S362/65/12 Turbo, 8x.011" Injectors, Denny T, 366 Spring, Piston Pump, SBC OFE Clutch, 4" Exhaust, M&H Timing Spacer, BHAF. |
#3 (permalink) |
I'd further those suggestions and say read read read. Read at least 3 detailed explanations of how to do the job before you do it. You don't need to remove the throttle linkage, you don't need to mess with the index... Just fyi.
91.5 W250. 518-360 Swap, 12cm housing, Keldermann air ride. |
#4 (permalink) |
Its nice to have an extra hand when doin this too!
91 W250 5 speed Built trans lots of fuel lots of air south bend clutch denny T stage II 5 inch exhaust traction bars ![]() OHIO COAL ROLLERS |
#5 (permalink) |
I got it done.
Index is right.I think?? Marks are like they were. BUT WHEN I TRY AND GIVE IT FUEL IT DIES. Idles fine but won't accellerate. What gives???????????????????????????????????????? Last edited by bmpmoss; 03-10-2010 at 04:32 PM. |
#6 (permalink) |
your throttle is not indexed right. just cuz it looks like its at the right marks doesnt mean its correct. keep playin with it till you get it right
SOLD: 91 d250 ic 5sp 92 d250 auto ext. cab. 366 spring. afc MIA straight pipe w/ 5in tip |
#8 (permalink) |
Please explaing this...I thought you had to remove all linkage???
1991.5 Dodge 250 -6bt. Auto 2wd,SCLB, Bone stock! seriously! I'm not kidding. Still has Factory muffler. Not a thing has been touched! |
#10 (permalink) |
then how are yall gettin to that allen screw underneath it?
#11 (permalink) |
i never even thought about trying to do it with the linkage on, ive just taken the linage off so many times that i just pop it off. id also like to know what method you would use to keep the linkage on.
#12 (permalink) |
Location: fort myers FL, only for about another 3 months. then GA
IMO i dont think there is a way to do it because the linkage is right on top of the bolt.
1992 d350 auto,gear vender,strait exuast,2nd gen intercooler,hx35. egt,boost,tach. 366 spring 1/4" timing, 2001 3500 with 600k miles k&n air filter and a superchips, and its balls less as balls less gets. |
