- - REGISTER - CALENDAR - INFO - SITE HELP - RULES - STAFF - MEMBERSHIP - ADVERTISE - CONTACT US - |
| 89-93 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
Another idea on Getrag 360 oil overfill
I've seen a manual tranny cooler that is basically an aluminum bolt on finned piece that sticks out and increases the oil capacity a little. It replaces the pto cover, which is standard size for many transmissions. Anyone ever use one or see one?
'93 W250 HD, 5 speed, 4.10's, 3200 rpm spring, straight pipe, 195,000 miles, 90 gallon fuel tank |
#2 (permalink) |
I just found the part, it is called "Fast Cooler" I found it on usdieselparts.com it is kinda pricey, and has a place for sending unit.
#4 (permalink) |
Genos im sure has them. check his site out.
1993 Dodge W250 Reg cab. Auto. Red Oak Diesel 5x.012s. .010" headgasket, A1 Technologies Head studs. Pump adjusted everyway i can for now. Timing bumped 1/4" and Aurora 3000 turbo. 4"-5" exhaust 7" Chrome CAT stack.
#5 (permalink) |
#6 (permalink) |
When overfilling the getrag you're trying to raise the level to lubricate the bearings, not just add more capacity.
91 W250, reg.cab 4x4, 5spd, 6" susp, 2" body lift, 36" Buckshots, Powersmoke IC, Banks high ram, Haisleys studs and fire rings, PDR valve springs, Bullydog boost and pyro(pre turbo)gauges, BHAF, 4" DP, dual 5" exhaust, HTB2 62/14, tweaked pump, 1/8 timing bump, 3200 rpm spring, POD's, 3.54 gears(in need of 4.10's) If it aint broke, the pedal is on the right I'm just smart enough to know when I've done something dumb, but stupid enough to do it again |
#7 (permalink) |
so lets say I order the one from genos an I add a temp guage does any body know what it would read or how much can it get hot with out hurting sorry I had seen them befor just never considerd but im pulling trailers now and I dont want to end up getting a new tranny!?
''1991 w250 LE 4x4 5 speed non Ic 3'' off the turbo 6'' tip'' pump turned up! Alot more "COAL ROLLING'' HX35 coming soon and single 7''stack
#8 (permalink) |
Ummm....if you don't slam and bang the tranny, if you don't lug it, and if you have a resonable amount of horsepower and your rag will stay with you for aloooooong time
93 3/4 ton 4x4 5-speed. pump bombed. Denny T. raptor 100 pump. 100 hp sticks. 2-inch leveling blocks. 12cm2 exhaust housing. Valair button Clutch proud contributor to global warming!!! |
