Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 03-09-2010, 08:56 PM   #1 (permalink)
91hoss's Avatar
Ring and Pinion Ratio???
I have a 1991.5 intercooled truck, 4x4, with an auto transmission. Can i find out what Ring and Pinion it is without looking? Or did the autos come with different ratios? Were they still making the 3.07's with the unique housing that differed from the rest? Thanks for the help guys.
91.5 W250, 35x12.50 Toyos, 2.5" Skyjacker Lift, Pump Turned UP, HE351 coming soon.
91hoss is offline   Reply With Quote
Old 03-09-2010, 10:46 PM   #2 (permalink)
1ST GEN MODERATOR
Philip's Avatar
The 3:07 could be had up into the 93 year model. Look under the hood. Towards the driver side of the truck should be a build sticker. It will have the ratio listed. If you can still read it.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, B&W flatbed
The Following User Says Thank You to Philip For This Useful Post:
91hoss (03-10-2010)
Old 03-10-2010, 12:15 AM   #3 (permalink)
91hoss's Avatar
if so would it be the odd ball axles?
Old 03-10-2010, 12:17 AM   #4 (permalink)
91hoss's Avatar
nevermind i just checked i have the 3.5's thanks!
Powered by vBulletin® Version 3.8.5
