8.3 air compressor on a 5.9? - Page 2 - Dodge Cummins Diesel Forum
post #13 of 24 (permalink) Old 06-04-2010, 03:39 PM
HighPlainsHP's Avatar
Hey Z, technically you need to mount the A. Comp to the front gear hsg., not it's cover...now, speaking from many years experience selling exactly what you need, get on in to your Cummins Distributor and find an 'experienced' partsman. If they're doin' their job they will search the available parts component options in text (PARTS BOOK and michrofiche!) or electronically and should be able to cover all the hurdles you're gonna run into. There are several B/W, Midland, Holset, etc. a. comp. drive options available since way before they were in these Dodges. Off the top of my head things like F. Pmp., vac. pmp., steering res./pmp. style and location are going to need to be addressed. It (the A. Comp.) will be located at the port in the housing where your vac./pwr str. is currently below the F. Pmp....gotta run, phone.
HighPlainsHP is offline
post #14 of 24 (permalink) Old 06-04-2010, 06:43 PM
cornman369's Avatar
the way ive seen them mounted is where the vac pump is on our trucks ans ps behind that also like our trucks
it would be great if you converted your trucks brakes to air assist or hydro rather vac, but then youd have to come up with a way to move the louvers it the hvac sys
ch
92 D250
fuller 13 speed and 3.07 swap in progress
99 24v 2500 sport auto
72 International Harvester 1110 soon to be 3-53Detroit diesel nv4500
cornman369 is offline
post #15 of 24 (permalink) Old 06-04-2010, 07:40 PM
Gots_a_sol's Avatar
use an electric vacuum pump like on the superturds?
I'd like to have a gear driven compressor on my truck as well, so hurry and figure out what we need to do it
Gots_a_sol is offline
post #16 of 24 (permalink) Old 06-05-2010, 03:56 AM
Im pickin up a us pullout 5.9 in a week or two. dudes throwin in two gear driven compressors. one is goin on my fuller conversion. ill get pics of how it all works out.
Makin-Smoke is offline
post #17 of 24 (permalink) Old 06-06-2010, 12:55 PM
Art
I have a Bendix air compressor off a 5.9 Cummins with a VE injection pump - PM me if interested.
WANTED: 1930 Dodge DD parts
lets go vintage drag racing:
Art is offline
post #18 of 24 (permalink) Old 06-06-2010, 04:12 PM
I Installed a Bendix 2150 9.5cfm air compressor on my Limo with a 94 6bt. The motor mount is different to compensate for the length of the compressor and there is a coolant kit you get from Cummins to route coolant from the head to the compressor. The Bendix compressor came of a VE pumped 6bt, so I know it will fit.
Also, I dont have a vacuum pump on the limo, just a large hydraulic pump for run my hydraulic steering system. I think you can get a vacuum pump for the mount, it is the most used diesel engine mount in the industry!
I think it ran me 350 total to install including purchase rebuild and everything.
liftedlimo is offline
post #19 of 24 (permalink) Old 06-06-2010, 04:16 PM
Here are some pictures that I found online. Mine looks identical to this one.
ID:	24878   Click image for larger version
ID:	24879   Click image for larger version
ID:	24880   Click image for larger version
ID:	24881   Click image for larger version
post #20 of 24 (permalink) Old 06-07-2010, 08:31 PM
...excellent info Limo, I left Cummins in '98 so some things are a little foggy! LOL!!
..."Torque is to win races, Horsepower is to sell cars"...Enzo Ferrari. Trucks:2011 Ram 3500 6.7 CTD, 97 FL50 w/6B & Allison 543, 88 F350 w/'90 6B & TF, 90 Ram 6B Diesel. Past long time Cummins employee...
post #21 of 24 (permalink) Old 01-09-2013, 05:55 PM
kind of out of the blue, and on an old thread, but any chance you still have that air compressor?
wkeelips is offline
post #22 of 24 (permalink) Old 01-09-2013, 06:12 PM
Jossi's Avatar
If you want a engine mounted air compressor on the cheap, get yourself a old Frigidaire AC pump off a early model car or truck, theres info online about converting these to airpumps....make up a bracket.
On your bottom pulley, weld on a pulley to drive it, and mount your tank under your bed....done deal....
"----If it ain't loud, lowered, long, and flatblack....an ain't belchin' black smoke...an don't have at least 1 Turbo....it ain't about S***!"-SCREAMIN' METAL
Jossi is offline
post #23 of 24 (permalink) Old 01-10-2013, 07:30 PM
Gots_a_sol's Avatar
I used a conversion pulley on mine. Replaced the alt. pulley and has a v-belt drive that I use to drive my compressor. (York)
00 Excursion -12v/nv4500. he351cw, 366 spring, 5x12's, THD piston pump
post #24 of 24 (permalink) Old 01-13-2013, 10:41 AM
deanhinsley1963's Avatar
If you can swing it the gear-driven comp. w/coolant cooling the head of the comp. is the way to go. The ones with the belt-driven york comp. work but are slow and build up quite a bit of heat.
92 D-350 Dually,Reg. cab C.T.D. Auto,3.54 limited slip,gauges,BHAF,3turns on smoke screw,2 turns on fuel screw,Denny T stage II fuel pin. 366spring and m&h timing spacer next!!!!
deanhinsley1963 is offline
