Engine torque specs? - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 02-19-2010, 11:15 PM Thread Starter
DSTAD's Avatar
Can some body please tell me what the torque specs are for the engine. Ect: Harmonic ballancer, bellhousing, converter, adapter plate.
I kinda need these tonight. Any help is greatly appricated
96 3500 2wd, ddp 2s, 3kgsk, #10 plate. Hybrid over s475, bd full roller bearing trans, DiPricol gauges, bd torq loc and tow loc, Pac brake 4 inline, Aux trans cooler with fan, Firestone ride rite with on board air/control, DSS, Centramatics, Maghytec, DDP Boost.
DSTAD is offline
post #2 of 14 (permalink) Old 02-20-2010, 09:39 AM
my92d350's Avatar
you dont realy need to torque anything you have listed. just use a good impact.
99 exlb 3500 auto 3.55 53 block unknown miles, stock other than bhaf and 4" exhaust
my92d350 is offline
post #3 of 14 (permalink) Old 02-20-2010, 10:03 AM
1ST GEN MODERATOR
Philip's Avatar
iTrader Score: 12 reviews
Engine adapter= 44 ft. lbs
flywheel= 101 ft. lbs
converter- 35 ft lbs
trans to adapter= 30 ft lbs
Now on the ballancer. I can't find it in the torque spec sheet.
2014/93 W350 DRW, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, air ride rear suspension,B&W flatbed
Philip is online now
post #4 of 14 (permalink) Old 02-20-2010, 10:11 AM
I Believe they are calling the harmonic balancer= the vibration dampner, It says 92 ft lbs.
or 125 N.M
91 non I/C. W350 flatbed SRW
1997 drw flatbed
hounddogks76 is offline
post #5 of 14 (permalink) Old 02-20-2010, 12:07 PM
BC847's Avatar
Are you serious?
David
Original owner of a plain'ol VE fueled '93 W250 ClubCab. Green
BC847 is offline
post #6 of 14 (permalink) Old 02-20-2010, 02:11 PM
i agree with him lol. A good torque with an impact is good with everything OUTSIDE the motor with headstuds being the only exception
96 one ton dually 4x4. 3ks. #10 plate slid and ground a bit. Resurecting from the dead. little paint work. Flatbed. Chrylser certified Tech.
pitman is offline
post #7 of 14 (permalink) Old 02-20-2010, 03:12 PM
my92d350's Avatar
exactly, some things have to be torque spect but some dont. all of them ive done in bolting stuff together, like tranys and bellhousings, ive never had a problem yet. to me it would be like torqueing the wheels
my92d350 is offline
post #8 of 14 (permalink) Old 02-20-2010, 04:17 PM
JBradley500's Avatar
the day you have a wheel fall off of your truck is the day youll learn the 8 lug torque pattern. there are lists out there that give you the size of the bolt/stud and a torque measurement so incase you cant find it youll have a good idea where it should be.
something like this...
SAE Bolt Torque Specs
92 W250- K&N Filter, Smoke Screw Adjusted, Synthetic Transmission Fluid.
340hp/662tq (8/24/12)
JBradley500 is offline
post #9 of 14 (permalink) Old 02-20-2010, 04:59 PM
The pattern has nothing to do with the torque specs. Of course you gotta tighten them in the star pattern and you dont even really have to do that if you stop and retighten the lugs after say twenty miles then your set. It all comes with takin good care of your truck. If you stoped to torque everything to factory specs then you would be there forever
pitman is offline
post #10 of 14 (permalink) Old 02-20-2010, 05:41 PM
You're supposed to re-torque your lug nuts 2 times after given amounts of distance driven. If you torque them you should take thr proper steps. It's kind of stupid not to.
As for torque patten, there is the star shape and 3 torque amounts(values) that you do in intervals to have the correct clamping force. Overkill? Maybe but I had a wheel fall off going 75mph once and it won't happen again.
post #11 of 14 (permalink) Old 02-20-2010, 05:51 PM
my92d350's Avatar
i know of the pattern, i do the star pattern and go up in 3 stages, on the 3rd time around i let the impact rip at full power. half the time i have to get the 1/2" impact out to get the lugs off. i dont think im guna have a problem with a wheel falling off.
my92d350 is offline
post #12 of 14 (permalink) Old 02-20-2010, 09:55 PM
BC847's Avatar
My goodness, Cummins torqued the bolts in my truck's engine and I've never had a problem with having to re-torque stuff for over 200,000 miles.
It's a shame all the trees killed to make the Cummins manuals that regularly reference torque specs.
It looks like DSTAD found what he was looking though ~ http://www.dieseltruckresource.com/d...s-t264359.html
David
BC847 is offline
