Getrag Gear Ratio - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 02-15-2010, 02:40 PM Thread Starter
91hoss's Avatar
Getrag Gear Ratio
Whats the Gear ratios in the stock Getrag 5 speed?
91.5 W250, 35x12.50 Toyos, 2.5" Skyjacker Lift, Pump Turned UP
1995 2500 4x4, NV4500, #10 plate slid forward, boost power fitting, 3GSK, Z-series pillar mount gauges
91hoss is offline
post #2 of 3 (permalink) Old 02-15-2010, 03:39 PM
1ST GEN MODERATOR
Philip's Avatar
iTrader Score: 12 reviews
1st: 5.531
2nd: 3.017
3rd: 1.60
4th: 1.0
5th: 0.77
R: 5.029
2014/93 W350 DRW, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, G56 SBC Con-OFE, 3:07's axles, 2" skyjacker lift, air ride rear suspension,B&W flatbed
Philip is offline
The Following 3 Users Say Thank You to Philip For This Useful Post:
91hoss (02-15-2010), bartonmd (02-15-2010), James-93-12valve (02-15-2010)
post #3 of 3 (permalink) Old 02-15-2010, 05:06 PM
Wow, I've got like 1800ft/lbs at the rear axle, if I'm in 2LO... (400 * 5.513 * ~2 * 4.10)
Mike
bartonmd is offline
