10 speed to 5.9 cummins - Dodge Cummins Diesel Forum
post #1 of 41 (permalink) Old 12-22-2009, 09:00 AM Thread Starter
Brandonsmokincummins's Avatar
so me and my buddy are doin a 78 dodge crew cab converison with a cummins in it but will a 10 or 13 speed eaton fuller bolt right up to the 5.9 cummins? It its gunna be our tow rig to the sled pulls and we wanted to throw a big semi tranny in it
91 W250 5 speed Built trans lots of fuel lots of air south bend clutch denny T stage II 5 inch exhaust traction bars
OHIO COAL ROLLERS
Brandonsmokincummins is offline
post #2 of 41 (permalink) Old 12-22-2009, 09:31 AM
JakeDiesel's Avatar
think that u can get 10spd that will i think they were in some frieghtliners with 10spd
94 Dodge 1500 2wd powered by a 2005 Cummins 3.9 4BTAA 27mpg 95 Dodge 2500 4x4 boost elbow (35psi) #10 fuel plate 99 2500 4x4 edge juice with attitude. 01 f650 with 5.9 cummins. 06 2500 all stock for now
JakeDiesel is offline
post #3 of 41 (permalink) Old 12-22-2009, 10:00 AM
iTrader Score: 17 reviews
get an SAE block plate, and you can bolt damn near anything to it
don't know why you'd want to, but more power to ya
drunk on diesel is offline
post #4 of 41 (permalink) Old 12-22-2009, 10:13 AM
cmnspwr05's Avatar
i think you can do a ten. theres a you tube video with a 2nd gen dually and a ten speed
04.5 3500 SRW-SBDD 3850-Motorsport Diesel-Exergy-Smarty-Industrial Injection-Turbo Smart-DPS-ARP-Blackhawk Diesel-Airdog-Pusher-Afe-Boost Fooler-Isspro EV2's-3" Kore-Pro Comp-33's with H2's
cmnspwr05 is offline
post #5 of 41 (permalink) Old 12-22-2009, 12:53 PM
seems like a huge waste of time/effort to me, but:
http://www.youtube.com/watch?v=2CG0Y...eature=related
post #6 of 41 (permalink) Old 12-22-2009, 01:59 PM Thread Starter
it might take some time but it would be cool and he has to money to do it thanks for the replys and video
OHIO COAL ROLLERS
post #7 of 41 (permalink) Old 12-22-2009, 02:03 PM
grizzly_man07's Avatar
i actually saw a video of a crew cab with a ten speed in it. ill try and find it
SOLD: 91 d250 ic 5sp
92 d250 auto ext. cab. 366 spring. afc MIA straight pipe w/ 5in tip
grizzly_man07 is offline
post #8 of 41 (permalink) Old 12-22-2009, 02:07 PM
unless you're towing VERY heavy with stock horsepower rating, I see no need to shift that many friggin' times! LOL
post #9 of 41 (permalink) Old 12-22-2009, 04:30 PM
Old 'n Rusty's Avatar
A lot depends on your axle ratio. With 4.10 it would be a waste of time. With 3.54 and a standard governor spring it would be somewhat desirable but with any taller gearing, specially if you plan to tow heavy, it would be real nice to have ten gears plus there is the durability of the Eaton-Fuller which would be unreal. Remember that as your rear-end gearing gets taller, the gap between the gears gets more troubling and making extra gears more necessary.
When my truck had 4.10 gearing I could easily shift up on steep hills because the jump to the next gear was not great. After I put in the 3.54 I found that the gap was too wide sometimes. The governor spring upgrade gave me the rev's so that I was able to make the shift up ok. The governor spring made up for the downside of the taller rear-end ratio plus it let the cummins keep its rev's up and reduce heat build-up, a critical issue for a non-IC'd cummins.
Also remember that just because you have ten gears doesn't mean you have to use them all of the time. You can make like you have a five speed when you are not pulling hard.
91 (08-90) D250
5sp 2wd 511k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'er
R60/7, Volvo 245 GL 320 k km's, f150 4x4 5 spd, MPG's are in Imp gal's
Old 'n Rusty is offline
post #10 of 41 (permalink) Old 12-22-2009, 10:17 PM
luckystars's Avatar
I do like the idea of going to an industral transmission. I'd pass on the 10 speed unless it had a Georgia overdrive, that would be sweet!
The mini wheeler dump trucks use an 8 speed with a low gear. You could start in 3rd or 4th. AND you'd get 2 revearse gears!!
2004.5 Dodge Ram 2500 QCSB 4x4 179,000 miles
If it ain't broke you're not using it enough.
luckystars is offline
post #11 of 41 (permalink) Old 12-22-2009, 11:27 PM
wjones's Avatar
you'd probably only use 5 or 6 of the gears while unloaded anyway. unless you really like rowing... I'll take one
, nv4500, Club Cab
wjones is offline
post #12 of 41 (permalink) Old 12-23-2009, 12:50 AM
every truck has a Georgia overdrive... also known as Mexican overdrive
The Following User Says Thank You to drunk on diesel For This Useful Post:
clthorn94 (07-17-2012)
