hard to get in gear? - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 12-21-2009, 11:40 PM Thread Starter
I have the stock getrag in my truck and when I try to put my truck in fear at a dead stop it won't go in at all. Nine times out of ten I gotta roll and most of them times I have to put it in other gears to get it in the gear I want. it goes into gear bueatifully goin down the road but its reallt aggrivating at a stand still. Is this normal?
96 one ton dually 4x4. 3ks. #10 plate slid and ground a bit. Resurecting from the dead. little paint work. Flatbed. Chrylser certified Tech.
pitman is offline
post #2 of 9 (permalink) Old 12-22-2009, 12:12 PM Thread Starter
Bump...anyone?
pitman is offline
post #3 of 9 (permalink) Old 12-22-2009, 01:23 PM
92cummins350's Avatar
Mine does the same thing. I'm not sure what the fix is, but mine will go into gear better if I downshift through every gear. Mine won't go into gear if I put it in neutral and roll to a stop, say from 4th, unless once stopped I go to 3rd then 2nd. I can't go from like 4th straight into 2nd. I don't know if you downshift or not when you stop, but if you don't try it and maybe it will at least make the truck more driveable until you can get it fixed.
92 w350 5 speed 4x4 flat bed. South Bend Con OFE, bigger sticks, a few turns on the fuel screw, KDP-killed, BHAF, straight piped w/ stacks.
92cummins350 is offline
post #4 of 9 (permalink) Old 12-22-2009, 01:33 PM
cornman369's Avatar
i had a k-5 that did this the master cyl for the clutch was weak and low on fluid,
put put fluid in it the next day the throwout bearing went
ch
92 D250
fuller 13 speed and 3.07 swap in progress
99 24v 2500 sport auto
72 International Harvester 1110 soon to be 3-53Detroit diesel nv4500
cornman369 is offline
post #5 of 9 (permalink) Old 12-22-2009, 08:36 PM
ZSkibo's Avatar
I'd guess your synchros are nearly shot unless the problem is predominantly 1st (I don't think it has a synchro for that gear; same shaft as reverse). Possible slave cylinder but I'd bet synchros.
92' W250, rhino liner bed+cab. Pump bombed: timing 18*, #366 spring, New Era 6x18's, #60 exh springs, 2ndGen piston pump (@18psi), BHAF, HX40 (60/65/18 T4), 6" hoodstack, full gauges, 4" PAC brake, Airchime P3, SOLD
ZSkibo is offline
post #6 of 9 (permalink) Old 12-22-2009, 09:54 PM
grizzly_man07's Avatar
does that mean new clutch or tranny rebuild? i have that problem
SOLD: 91 d250 ic 5sp
92 d250 auto ext. cab. 366 spring. afc MIA straight pipe w/ 5in tip
grizzly_man07 is offline
post #7 of 9 (permalink) Old 12-22-2009, 10:05 PM
90powerram's Avatar
Before pushing the stick into gear, I let the clutch pedal out a bit just for a second, then push it back down, to get the shafts/gears turning inside the trans. Then it slides into gear much more easily.
2002 Ram 2500 24V 6-spd, 4" exhaust & AFE intake
90powerram is offline
post #8 of 9 (permalink) Old 12-22-2009, 11:08 PM
luckystars's Avatar
Mine did that before I took out the 90 wt and put in 15-40
The 1 qt extra and the 90 wt is too much for the syncros and gears IMHO
This is assumming that the clutch is not warped and the disc is releasing.
2004.5 Dodge Ram 2500 QCSB 4x4 179,000 miles
If it ain't broke you're not using it enough.
luckystars is offline
post #9 of 9 (permalink) Old 12-23-2009, 12:11 AM
My Getrag's 2nd and 4th gears are fine but it has a notchy 3rd gear, especially when cold. But I would agree with Zskibo about having worn synchros. I need to do a drain and refill and see if that makes any difference.
Slow69Chevelle is offline
