High idle - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 03-19-2017, 03:15 PM Thread Starter
High idle
Here we go again I'm trying to get my idle lowered it's at 1000 now. I ground the idle screw has been ground and I tried adjusting the linkage with no luck I can still see light between the lever stop and idle screw. Do I need to reindex the throttle? If so where should I set it. Thanks in advance.
1993 2x4 extended cab dually/ thd fuel pin/366 spring/steel braided fuel lines/crazy Carl's steel throttle linkage/ pump advanced to head/ he351 turbo/ 6x.013 injectors/ 15 psi piston lift pump/ 4" dp to 5 inch straight pipe
Tcast09 is offline
post #2 of 11 (permalink) Old 03-19-2017, 03:45 PM
Moderator
9297oldram's Avatar
You probably need to adjust the ball linkage, spread them apart.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 SC zf5, 4x4, SAS, 92 Cummins, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod, WM, wh1c hybrid 60/64/.82a/r
9297oldram is online now
post #3 of 11 (permalink) Old 03-19-2017, 04:16 PM Thread Starter
I loosened the nuts and screwed the ends out on the rod it seems to be maxed out
Tcast09 is offline
post #4 of 11 (permalink) Old 03-19-2017, 04:20 PM
Moderator
9297oldram's Avatar
What happens when You pop off one of the ball ends on the linkage, will it touch the idle stop?
post #5 of 11 (permalink) Old 03-19-2017, 04:26 PM Thread Starter
No it doesn't there's still a gap
Tcast09 is offline
post #6 of 11 (permalink) Old 03-19-2017, 04:44 PM
Supporting Vendors
RCCUMMINS89's Avatar
Put a stronger return spring on it.
RCCUMMINS89 is offline
post #7 of 11 (permalink) Old 03-19-2017, 04:49 PM Thread Starter
Alright I'll give that a try
Tcast09 is offline
post #8 of 11 (permalink) Old 03-19-2017, 04:52 PM
Moderator
9297oldram's Avatar
If you pull the IP arm to the stop will it touch?
post #9 of 11 (permalink) Old 03-19-2017, 07:33 PM Thread Starter
No not quite
Tcast09 is offline
post #10 of 11 (permalink) Old 03-21-2017, 12:15 PM
89ralph's Avatar
i had the same problem, the linkage ends kept getting hung up, i replaced it with a kit from crazy carls turbo, worked out great, and was on sale
89 w250,2nd owner, 160k miles, 727, straight pipe, tuned afc, kdp.
89ralph is offline
The Following User Says Thank You to 89ralph For This Useful Post:
TURBOLVR (03-23-2017)
post #11 of 11 (permalink) Old 03-21-2017, 10:24 PM
Supporting Vendors
Question, is your idle screw backed all the way out? And it won't touch? Can you post a picture of where it's at?
