Sudden loss of boost. - Dodge Cummins Diesel Forum
post #1 of 14 (permalink) Old 02-17-2017, 12:09 PM Thread Starter
grizzlypaugh's Avatar
Hey! Been awhile since I been on here. This morning I lost almost all of my boost. It only goes to 5 psi. Its cloudy behind me and my EGT goes hi really fast. I'm going to start to look for boost leaks.
grizzlypaugh is offline
post #2 of 14 (permalink) Old 02-17-2017, 12:25 PM
myother4x4isaCJ7's Avatar
Pull the intake off the turbo and make sure the wheel spins free too. I'd bet you ripped a boot and have a massive boost leak though.
1993 w250 club cab ,flatbed, bd pin and gov spring, turned up pump, 4" diamond eye and THD 6x11s
myother4x4isaCJ7 is online now
post #3 of 14 (permalink) Old 02-17-2017, 01:31 PM Thread Starter
Good idea! Thanks! Stock boots! Lol
post #4 of 14 (permalink) Old 02-17-2017, 01:32 PM
Moderator
9297oldram's Avatar
If it happened all of a sudden it's probably a connection, If it is a rubber boot and you can't find one quick radiator hose will work.
Been using that on mine for about 5 years and still holding strong.
97 2500 4X4 auto, 8 fuel plate, BD converter
96 F250 SC zf5, 4x4, SAS, 92 Cummins, Bosch 190's, THD fuel pin, THD HVLP with adjustable fuel pressure mod, WM, wh1c hybrid 60/64/18.5
9297oldram is online now
post #5 of 14 (permalink) Old 02-17-2017, 02:23 PM Thread Starter
Ill keep the radiator hose idea in mind! Where is a good source for boots?
post #6 of 14 (permalink) Old 02-17-2017, 03:30 PM
BlaineKaiser450's Avatar
I vote boost leak as well. I've bought boots off of Amazon and they seem fine and didn't cost much.
1993 White Dodge W350 Dually, Built 46rh, IP Mods, Hungry Diesel Fuel Pin, Stiffer AFC Spring, 62/68/12 FMW, DAP 5x14s, Raptor 150 Lift Pump, 4 Inch Exhaust, 120K, 3.55s, 6 Inch Lift, ORD Crossover Steering, 35x12.5x20s
BlaineKaiser450 is offline
post #7 of 14 (permalink) Old 02-17-2017, 03:45 PM
Or this place Silicone Hose every shape color and size.
post #8 of 14 (permalink) Old 02-17-2017, 05:54 PM Thread Starter
Thanks guys! As right now I can't see any visible damage to my boots. Gonna look a little harder here in a few.
post #9 of 14 (permalink) Old 02-17-2017, 09:03 PM Thread Starter
Hey guys I can't seem to find a leak. I took it for another test drive and I don't even hear my turbo spooling.
post #10 of 14 (permalink) Old 02-17-2017, 10:42 PM
Did you inspect turbo yet? Could have issues.
post #11 of 14 (permalink) Old 02-17-2017, 10:53 PM Thread Starter
I took off the intake and the turbo spins fine with no play. I started it with no intake and the turbo sounds normal. Just no spooling. Just plenty of unburnt fuel lol
post #12 of 14 (permalink) Old 02-18-2017, 01:38 PM
Maybe check your intercooler? I've heard of them coming apart and leaking. Also check your intake plate gasket, I don't think it would be that great of a leak.
