Front Drive Shaft - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 12-07-2009, 12:25 PM Thread Starter
TTipsword's Avatar
Front Drive Shaft
Hey i have a quick question. In 4x4 i get a vibration. If i really get into it the vibration goes away. I looked at my drive shaft and noticed that the joint at the T-case is shot. I don't know the name for it but it is the piece that connects the drive shaft u-joint and the input u-joint for the T-case. What is this called and will this solve my vibration problem. Also it doesnt turn in 4x4 as it should, feels like the drive shaft is binding.
1992 dodge W250, pump maxed, cooler tubz, Denny T pin, SDX 5x.014's
TTipsword is offline
post #2 of 9 (permalink) Old 12-07-2009, 08:51 PM
huntinguy's Avatar
That is a CV joint. It pretty expencive. your probably better off buying a whole new drive shaft.
That should take care of the vibrations.
89 w-250 4" lift, 4" exaust, tuned pump, electric lift pump, timing to the head, 2nd gen cooler, 500hp clutch, HE351VGT and a still under the hood.
other trucks- 89 w-250, 92 w-250
huntinguy is offline
post #3 of 9 (permalink) Old 12-08-2009, 03:01 PM
jfc
jfc's Avatar
I asked at dodge up here, and they said dodge don't make the front driveshaft anymore, where could you buy one?
92, 250, ext cab, 4x4, 5 speed
jfc is offline
post #4 of 9 (permalink) Old 12-08-2009, 03:22 PM Thread Starter
TTipsword's Avatar
used i guess i dunno.
post #5 of 9 (permalink) Old 12-08-2009, 03:41 PM
Any competent driveshaft shop should be able to make you a new one. It will probably not be cheap, but it might be easier than trying to locate one. Check out this forum and you can see the one this guy made for his '92.
Project: Doitall Dodge - Expedition Portal Forum
Slow69Chevelle is offline
post #6 of 9 (permalink) Old 12-08-2009, 03:48 PM
Look in the Yellow pages for a machine shop that does drive shafts, or Dan-co there are lots of them that can repair it for you. Phone you local 4x4 clubs and ask where they get there's done at. Call your local class eight dealership and ask them who they use for drive shaft repair.
JP 3 :Licenced HD mechanic for 35 years. RETIRED!
worked on engines all my life. Spent last 19 HAPPY years at Freightliner:
jpringle3@hotmail.com is offline
post #7 of 9 (permalink) Old 12-08-2009, 04:37 PM
huntinguy's Avatar
Rock auto has them for around $300. Napa has it for about the same.
post #8 of 9 (permalink) Old 12-12-2009, 12:10 PM
Left out in the cold's Avatar
Napa only sells ones for automatic transmissions. How ever, they do list all the parts to rebuild yours.
Left out in the cold is offline
post #9 of 9 (permalink) Old 12-12-2009, 09:31 PM
rmauto1's Avatar
My buddy had one made for his 01' cost him 200 for the whole ball of wax. It was a thing of beauty too.
93 W-250, CTD, Intercooler, stock pump settings, gertrag,
3.54 gears, straight pipe, DMI bumper, 121,000 miles.
rmauto1 is offline
