Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 12-06-2009, 12:39 AM   #1 (permalink)
Need a pic
I need a picture or an exploded view from a manual of the rear drum brake assembly off of a 91 w250. Some genius removed all the brake shoes and hardware and put the drum back on so I had absolutely nothing for brakes on the rear passenger side of my truck. I just need a good pic to make sure I get all the parts I need to rebuild it.
91 W250, 5spd Getrag, 284000+ on the clock, stock
Neil Oltrogge is offline   Reply With Quote
Old 12-06-2009, 06:55 PM   #2 (permalink)
hoggridge's Avatar
Sorry, don't have a pic BUT.........Have been in this situation before. If you can remove the drum from the other side, it will show you everything that's required and where it goes. Use the other side as your pattern. Hope this helps.
93 W250 5spd LE Club Cab, 4" Skyjacker, 35x13.50x18's, 18x10 racelines, Cooltubz, DDP injectors, BHAF, 4" exhaust, autometer egt & boost, smoke 2 turns, power 2 turns, more Pump mods when parts arrive.......
hoggridge is offline   Reply With Quote
Old 12-06-2009, 08:09 PM   #3 (permalink)
Yeah I am going to do that but after finding this train wreck I wanted one that was known to be correct incase there is something that is messed up on the other side as well.
Old 12-06-2009, 11:16 PM   #4 (permalink)
not exactly what you're looking for but it might help...
1992 W250, Getrag Club Cab
wjones is offline   Reply With Quote
The Following User Says Thank You to wjones For This Useful Post:
Neil Oltrogge (12-06-2009)
Old 12-06-2009, 11:47 PM   #5 (permalink)
That is exactly what I was looking for as long as the other side adjuster is assembled right I should be able to make sure I get it put back together correctly. Thank You
Old 12-07-2009, 11:20 AM   #6 (permalink)
406Cummins's Avatar
Maybe this will be of some use.
91.5 W250CTD, Automatic, Pot Controlled Overdrive, PODS, Isspro Boost & Pyro, Pump maxed, 3200 Spring, HTT 62/65/13 Wastegated at 40psi, Pin shaved, Advanced timing to head, 5" Bullhaulers
406Cummins is offline   Reply With Quote
Old 12-07-2009, 06:00 PM   #7 (permalink)
i would like a pic of the adjuster wheel and the cable set up on that if anyone has one. I just want to make sure I get it assembled right.
Old 12-07-2009, 10:33 PM   #8 (permalink)
try this:
A Boy and his Jeep Dana 60/70 Rear Drums
freak007 is offline   Reply With Quote
The Following User Says Thank You to freak007 For This Useful Post:
Neil Oltrogge (12-08-2009)
Old 12-08-2009, 03:13 AM   #9 (permalink)
freak007 that is a great write up thanks for the info I will have to drag my laptop out with me to do this now.
Powered by vBulletin® Version 3.8.5
