Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 11-06-2009, 11:40 PM   #1 (permalink)
crisdog80's Avatar
Unhappy oil in my antifreeze
i have oil in my antifreeze is it a blown head gasket i need help i am freaking out please help me
1993 dodge cummins w250 12v
crisdog80 is offline   Reply With Quote
Old 11-06-2009, 11:45 PM   #2 (permalink)
ZSkibo's Avatar
Either that or your oil cooler. Both are not fun to do, but not horrible either.
92' W250, rhino liner bed+cab. Pump bombed: timing 18*, AFC out, #366 spring, POD's, #60 exh springs, 2ndGen piston pump (@18psi), BHAF, HX35/40 (60/60/12), 4" turbo back 6" stack, full gauges, Banks engine brake, onboard air, train horns!
ZSkibo is offline   Reply With Quote
Old 11-06-2009, 11:46 PM   #3 (permalink)
ZSkibo's Avatar
I'd say don't freak out about it, just get it fixed. You'll be fine.
Old 11-06-2009, 11:46 PM   #4 (permalink)
ynots57's Avatar
the worse case scenario is a blown head gasket, ive never heard anything about cummins warping the heads
2005 3/4 SRW 48RE QUAD L/B 4x4 AEM AERO
ynots57 is offline   Reply With Quote
Old 11-07-2009, 12:09 AM   #5 (permalink)
crisdog80's Avatar
Unhappy
so how do i fix the oil cooler have like a $500 bank
1993 dodge w250 3200 spring, 2nd gen intake, turned up VE, PULL CABLE CULB MEMBER, pushing 30 psi with stock turbo, previously hydro locked the engine
Old 11-07-2009, 12:51 AM   #6 (permalink)
crisdog80's Avatar
Unhappy
can i still drive it it my only form transportation
Old 11-07-2009, 02:30 PM   #7 (permalink)
crisdog80 I noticed that in another thread you say in your signature that you hydroliced your engine, it is possible that you did pop your head gasket when you hydroliced your engine. does the oil add alot to the cooling system and/or does your engine oil level drop lots in a day of normal driving? Its not too hard to pull your engine oil cooler off to have it tested just have the install gaskets ready if it passes the pressure test. as for the head gasket its not that bad there are quite a few guys on this site that have done the head gasket re&re so search the threads.
92 D250 Club Cab LE, BD converter, BD pyro, BD boost, Issapro temp, 16cm turbine housing, 100hp injecters, fuel screw bottomed, (not sure about star wheel yet), new linkage ends, 200 litre extra fuel tank.....so far (POM's)
mrmoparwl is offline   Reply With Quote
