Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 11-06-2009, 10:24 PM   #1 (permalink)
dieselfreak01's Avatar
white smoke
i havent drove my truck in a couple weeks due to rear brake problems so tonight i put in the garage to start working on it and break the line, long story short i start it up to pull it back outside and it starts fine but the idles like its only on 3 cylinders or something, trucks rocking and engine sounds bad/ it clears up so i put some fuel to it to idle up and it starts it again only with white smoke. my only guess i can come up with is that i have an injector sticking but would like some input or ideas. thanks guys.
'93 d350 drw auto 167000 on the odometer and still running strong, 3.50 gears, ext cab soon to be 5" dp back exhaust
proud member of the OHIO COAL ROLLERS
dieselfreak01 is offline   Reply With Quote
Old 11-07-2009, 12:23 AM   #2 (permalink)
BridelessRacing's Avatar
Drain a little fuel out of filter see if it has any water in the fuel.
2003 quad cab powered by 91 12 valve ve44 pump with 62 CC head fuel pin 80+ injectors 3 inch turbo with a 48RE automatic. Set up to run on strait waste grease, Biodiesel or NO2 http://community.webshots.com/user/bridelessd7
BridelessRacing is offline   Reply With Quote
Old 11-07-2009, 12:28 AM   #3 (permalink)
crisdog80's Avatar
is it cold out side?
1993 dodge w250 3200 spring, 2nd gen intake, turned up VE, PULL CABLE CULB MEMBER, pushing 30 psi with stock turbo, previously hydro locked the engine
crisdog80 is offline   Reply With Quote
Old 11-07-2009, 02:53 PM   #4 (permalink)
no not really it was chilly last nite but not cold
Old 11-07-2009, 04:03 PM   #5 (permalink)
Mine does the same thing but like you I'm not sure either.
Ledfoot is offline   Reply With Quote
Old 11-08-2009, 06:34 PM   #6 (permalink)
that and i finally turned the pump up and now i cant get the idle to down
