Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 11-06-2009, 10:13 PM   #1 (permalink)
three lights flashing when flasher on?
I turn on my flasher and three lights flash but passenger side front light won't.
but the turn signal flashes
any help out there
Fire Buster is offline   Reply With Quote
Old 11-07-2009, 03:03 AM   #2 (permalink)
ridemoto4life's Avatar
flasher relay wiring? sending out power but lost somewhere in the loom?
91.0' W350 SRW LE. 727 3.54s, Dana 80 LSD, 265/75R16E, 366 spring, THIN pin, pump maxed, what starwheel? timing bumped, BHAF, 3.5" straight pipe, rear bagged, Isspro gauges, Hella H4s, Borg shaft.... COMING SOON! big sticks, HX40, 47RH/NV? & DRW swap
ridemoto4life is offline   Reply With Quote
Old 11-07-2009, 03:12 AM   #3 (permalink)
H.R.D's Avatar
Either that or a new flasher relay...would be my guess...use a digital multi-meter at the relay then at the light. Check Resistance and voltage.
2002 3/4 ton X-cab SWB 4x4 5 speed, Volant CAI, Blue Chip VP44, Edge J/A*HOT*, PDR HX40, AD 100, CFM+, BD short shift, TRAIN HORNS, 4" 2 6" Black Mitre's!!! www.hotroddieselclub.com its the myspace for diesels!!!
H.R.D is offline   Reply With Quote
