| 89-93 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
injector #3 NOT COMING OUT!
The first injector came out nicely. The second injector was rough. The third will not come out. It's loose and will spin 360; I just made an 8' lever with a 4x4 and still not coming out. Open to suggestion....
#4 (permalink) |
Mine where pretty carboned up. Let the penetrating oil work on it for a while.
91.5 I/C W250 5sp 3.07s turned up pump 16cm2 M&H M2 BHAF Bosch +40s 92 W250 Xcab auto 3.54 bonehead stock |
#5 (permalink) |
Back nut up blowdirt and rust out with compressed air. Fill threads around injector with JB80 let it soak for 15 minutes. Start wiggleing injector should come right out
2003 quad cab powered by 91 12 valve ve44 pump with 62 CC head fuel pin 80+ injectors 3 inch turbo with a 48RE automatic. Set up to run on strait waste grease, Biodiesel or NO2 http://community.webshots.com/user/bridelessd7 |
#6 (permalink) |
did you get it out ?
1993 dodge w250 3200 spring, 2nd gen intake, turned up VE, PULL CABLE CULB MEMBER, pushing 30 psi with stock turbo, previously hydro locked the engine
#8 (permalink) |
I bought a metric nut from Napa that fit the injection line threads. I set one of the other hold down nuts on top of the one on the injector and used it like a spacer. I finger tightened the metric nut down then backed off the hold down nut on the injector. It backed right out.
