| 89-93 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#13 (permalink) |
Thats what i was thinking. I just out a new one in and i think there is a little bypass in it but jfc just put a new one on and hes still having the same problem
91' D250 w/ Lil Red Express Bed stacks, Soon to be tweaked FP and Custom fuel system. |
#14 (permalink) |
Guess its possible I got a bad LP from NAPA, but i wana try bleeding it properly, Any suggestions on how to easily turn the crank 90 degrees? the lift pump primer does nothing when in the wrong position on the shaft, and when I crank the engine over it always stops on the same spot.
92, 250, ext cab, 4x4, 5 speed |
#15 (permalink) |
Well i've been out there fooling with the truck and i just cracked the lines at the injectors and the third injector in was just bubbling and no fuel. so i gave it sum throttle and just kept bubbling and then now it wont go back to an idle. PS I'm taking a break because i have an exhaust leak at the turbo so i'm getting exhaust in my face.
#16 (permalink) |
that is what i was also wondering because what you have going on is not so much a rough idle as a surging.
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro. God Bless Our Country and Damn The Goverment |
#17 (permalink) |
Found it. The fuel hose that leads into the lift pump had a small rip in it and it was pulling air into the system. So JFC idk if u checked that yet but that was my problem. now i'm onto fixing my exhaust leaks.
#18 (permalink) | |
I wish I was on to fixing exhaust leaks ![]() Sheff did you pressurize your tank to find the spot? and if so how?
#19 (permalink) |
Well this morning was the ultimate test and it failed. Still having the problem.
#20 (permalink) |
Well my LP is done it wont hold pressure. But i found the main problem. Where the orange line is, thats the crack in the injector.
#21 (permalink) |
that suck sheff, I will see if I got any cracks, i put some air pressure in my fuel tank, and didn't find any leaks, the only thing I found was air coming out at the top of the tank possible from the fuel return line, hard to tell
#22 (permalink) |
Yeah I only noticed it after i cracked the line at the injector and it was wet with fuel and i saw it bubbling. Use wd40 if you don't want to crack your injectors again
#23 (permalink) |
Or is that the rubber dust seal, a square o-ring that is cracked. Most of mine looked that way when I change my injectors. Look at the back of the injection pump where the lines come out for leaks. Check the bolts on the block.
91.5 I/C W250 5sp 3.07s turned up pump 16cm2 M&H M2 BHAF Bosch +40s 92 W250 Xcab auto 3.54 bonehead stock |
#24 (permalink) |
I think its my injectors..... as I washed the engine so I could see leaks ext better, and I got a fuel leak around the botom of three injectors....only had one leaking a year ago...... thats when I bought a set of injectors and never got around to it...
