Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 11-05-2009, 10:37 PM   #1 (permalink)
4.10 rpm?
what rpm's should a stock 91 w250 with 4.10 gears get at 60?
kk1992 is offline   Reply With Quote
Old 11-05-2009, 11:11 PM   #2 (permalink)
zrultima's Avatar
It is going to be at 2000 rpm
Do you know what "nemesis" means? A righteous infliction of retribution manifested by an appropriate agent. Personified in this case by an 'orrible cunt... me
zrultima is offline   Reply With Quote
Old 11-06-2009, 12:54 AM   #3 (permalink)
With new stock 235/85/r16 tires and a getrag 5 speed in 5th you'll be at 2000 rpm.
1991.5 W250 3.55 Auto CTD. DDP4, modified DennyT pin, 366, He351, 4" turbo back straight pipe, bumped timing. ~ 251.4hp/562.5 tq corrected ~ Borgeson shaft, Amsoil 4091 air filter, home-made intake, Amsoil 5W-30 synth. w/ bypass.
Richard LeBar is offline   Reply With Quote
Old 11-06-2009, 01:27 AM   #4 (permalink)
Old 'n Rusty's Avatar
4.10 is great for pulling heavy. It puts your shift points close together. Around town you will find it kinda busy and the slow shifting will bug you because you run out of rev's fast. 4.10 won't give you a lot of speed on the highway. I switched mine to 3.54 and have not regretted it. First gear becomes useful, specially when pulling a heavy trailer. The 3200 gov. spring helped make up for the wider gear spacing.
91 (08-90) D250
5sp 2wd 497k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'er
R60/7, Volvo 245 GL, f150 4x4 5 spd, Ram 318, MPG's are in Imp gal's
Old 'n Rusty is offline   Reply With Quote
Old 11-06-2009, 10:14 PM   #5 (permalink)
how about with larger tires. 35 to 38's lets say
Old 11-06-2009, 11:17 PM   #6 (permalink)
1930 rpm give or take a little with 33" tires
1820 rpm give or take a little with 35" tires
1770 rpm give or take a little with 36" tires
1720 rpm give or take a little with 37" tires
1675 rpm give or take a little with 38" tires
