| 89-93 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
got a leak
went out to start my truck this morning and found a small puddle of diesel after it warmed up. it looks like it is coming from the back of the pump? there is a rubber piece that has a very small hose lookin thing coming out of the side. it pops off what i think is the fuel screw but not sure. got any answers?
1990 d250, 5 speed, 4.10 rear, pump turned up a little. 3200 spring, new paint, stacks to come |
#2 (permalink) |
1ST GEN MODERATOR
![]() Join Date: Nov 2007
O-ring on the fuel pin is leaking. The top will most likely have to come off and replace it.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto, 3:07's axles, 2" skyjacker lift, B&W flatbed |
#3 (permalink) |
what do you mean take the top off? not to sound ignorant about this but i kinda am when it comes to the pump side of things. and would any o-ring from the parts store work?
#4 (permalink) |
1ST GEN MODERATOR
I dought if a dime store o-ring will work. They don't hold up against diesel fuel to good. Plus that o-ring is small in dia, but it is thicker than a normal o-ring. Even a metric o-ring. You would need a Ve reseal kit to acquire the correct o-ring.
#5 (permalink) |
This is exactly what happened to mine yesterday - started it up after work, and there was a steady dripping from the shut-off solenoid area, about 3 drips every 2 seconds. Sorry to hijack the thread, but is resealing the VE a job someone can do easily? I'm in BC, are there any places that sell kits? Thanks.
1990 W250 4WD 5-speed, factory 1-ton suspension Mostly stock for now, pyro, 3.54's & Toyo M/T's |
#6 (permalink) |
I am getting ready to tackel my leaky fuel pin seal. shouldnt be too bad and since u are going to have the top off you mine as well spend $20 and drop a govenor spring in too.
93 W250 4x4 125k auto hx40 recon smoked cab lights lots of body work injectors coming soon 01 2500 4x4 auto 2" leveling kit tail lights silencer ring MIA Edge Juice with Attitude custom 4" into dual 6" stacks AEM gauges
#7 (permalink) |
do i have to take the whole pump off to get the top off? and where can i get the kit? i saw some on ebay but i figured theres a better place to buy them.
#8 (permalink) |
well i was just gonna order my kit off ebay. no u dont have to pull the whole pump off to get to it. there are 4 allen head screws i believe you have to take out along with the TPS if urs is a newer auto and the banjo bolt and then u should be able to pull the top half of the pump off to get to the seal. the seal will be on the bottom half of the top part u pull off and then if you look inside the pump u will see the govenor spring. i havent had the top off mine yet but i will here in the near future.
| The Following User Says Thank You to 1stgen3rdgendodge For This Useful Post: | JDK (11-08-2009) |
#10 (permalink) |
The black rubber piece is a cover for the AFC vent. When the AFC diaphragm moves it displaces air so the cover must be vented. Get yourself some very detailed instructions cause this is not a simple little job if you have never done it before. 90powerram- what part of BC? I'm in PG- maybe I can help. |
#12 (permalink) |
if its coming from underneath the diaphragm then you will need to replace the fuel pin seal cause there shouldnt be diesel laying underneath there
