Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 11-05-2009, 02:35 AM   #1 (permalink)
7.3 4x4 power's Avatar
Pump
OK so ordered a new pump today for my 93 and is being shipped friday so my question is how do i turn er up slightly i know it consists of turning your rpm down but know no more im not a genius on the cummins like i am with the idi ford engines
08 DODGE 2500 QCLB single 4x4 6.7 24v manual. edge, dpf mia, unpluged egr, and runnin 33's camo seat covers ranch hand front headache rack ranch hand and 2.5 level kit tool box and aux fuel tank04 cummins stick-02 cummins auto-93 cummins auto 2wd's
7.3 4x4 power is offline   Reply With Quote
Old 11-05-2009, 04:51 PM   #2 (permalink)
Old 'n Rusty's Avatar
You can turn up the fuel by turning the fuel screw. This won't do as much for your small injectored IC'd '93 as it does for the older ones. Watch out for a run-away if you turn it up too much. I would install the new pump, get it all working well and then play with the adjustments. Not every 'new' pump is perfect and it is a good idea to see if it works well before getting into the adjustments. When you do turn up the fuel, the idle rpms will climb then you should turn down the idle. Our linkages are often worn. Check to see if you are getting full throttle when the pedal is on the floor. I have had to fiddle with mine a lot before I got anything like wot.
91 (08-90) D250
5sp 2wd 497k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'er
R60/7, Volvo 245 GL, f150 4x4 5 spd, Ram 318, MPG's are in Imp gal's
Old 'n Rusty is offline   Reply With Quote
Old 11-07-2009, 03:25 AM   #3 (permalink)
ok cool im not looking for extreme fuel just a little bump in it to help this slow truck out and i didnt mean 'new' its new to me but its a reman does it still need lots of adjustment?
Old 11-07-2009, 10:58 AM   #4 (permalink)
powerbrake's Avatar
where did you buy your remanufactured pump from? when mine went out i could only find one place that had them in stock and that was columbus diesel. i had to give them the core charge because my core was un-rebuildable. my core was gernaded when the govenor flew apart.
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro.
God Bless Our Country and Damn The Goverment
powerbrake is offline   Reply With Quote
Old 11-09-2009, 12:29 AM   #5 (permalink)
Some pumps are set-up beautifully and some are not. Usually they are pretty close. Sometimes they are not properly rebuilt. That is why I would install it first, get it running well and then tweak it. That way you will know whether it is a problem with the pump or a problem with your tweaking. I can't tell you how many times I have made a number of changes at the same time and came to regret it later. Be patient and make one change at a time.
91 (08-90) D250
