| 89-93 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#2 (permalink) |
10 mm wrench to remove return line 17 mm wrench to remove injector line. Remove lines then pull all injectors with slide hammer have all tested should pop at 3500psi.
2003 quad cab powered by 91 12 valve ve44 pump with 62 CC head fuel pin 80+ injectors 3 inch turbo with a 48RE automatic. Set up to run on strait waste grease, Biodiesel or NO2 http://community.webshots.com/user/bridelessd7 |
#5 (permalink) |
how to make an injector puller. they come out easy this way http://www.dieseltruckresource.com/d....html?t=124728 how to change them Injector Change |
#6 (permalink) |
30 mm deepwell to remove injector nut sorry I forgot that
