Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 11-03-2009, 08:23 PM   #1 (permalink)
newbi with lots of questions
hello, im new to the forum, i have some questions about my dads truck, its a 1990 3/4 ton, 4x4. what make of transfercase is in the truck, im trying to get enough info so i can make a new mount from the 3 speed auto to the transfercase, i also want to know how i can make a little extra power without sacrafise to the fuel economy. it has a little under 200k recorded kilometers on it, probably closer 2 240k. Thanks
90bonestockcummins4X4 is offline   Reply With Quote
Old 11-03-2009, 08:28 PM   #2 (permalink)
grizzly_man07's Avatar
well. max out your pump. get bigger injectors and turbo. do this all by gloing here Turning up the pre 94 Ram diesel injector pump
and fuel miliage depends on how you drive
91 d250, pump maxed. 1/8 in bump timing. BHAF for Freightliner. POD's. HX35 on the way. then puttin this baby on Meth single stack "rollin coal"
grizzly_man07 is offline   Reply With Quote
Old 11-03-2009, 08:41 PM   #3 (permalink)
how does the motor respond to the power, does it loose the longevity? Thanks for the link.
Old 11-03-2009, 08:48 PM   #4 (permalink)
the motor will have more torque and hp. and the only way it will mess it up is if you rag on it, and run that engine really hot. all the mods in that link, were designed when they built the ve pump. so i guess you could say they were meant to be tweaked lol. its the same thing as puttin a chip or programmer on a newer truck... it feeds more fuel to the engine
Old 11-03-2009, 08:59 PM   #5 (permalink)
rmauto1's Avatar
Welcome!! Your dads truck should have the np205 transfer case.
93 W-250, CTD, Intercooler, stock pump settings, gertrag,
3.54 gears, straight pipe, DMI bumper, 121,000 miles.
rmauto1 is offline   Reply With Quote
The Following User Says Thank You to rmauto1 For This Useful Post:
90bonestockcummins4X4 (11-03-2009)
Old 11-03-2009, 09:02 PM   #6 (permalink)
haha almost forgot. welcome to the forum. if you do some searching in the performance discussion, youll find everything u need to know
The Following User Says Thank You to grizzly_man07 For This Useful Post:
Old 11-03-2009, 09:54 PM   #7 (permalink)
1ST GEN MODERATOR
Philip's Avatar
If you do not have a pryo installed on that nonIC truck. Be very carefull on turning it up. It has bigger injectors that a IC truck. The turbo is smaller than a IC truck. It doesn't take much to get into EGT problem.
Old 11-04-2009, 10:20 AM   #8 (permalink)
so before i do any tweeking im gettin a set of gauges, im also doing some research on the possibly of mounting an intercooler under the hood, if thats possible that is
Old 11-04-2009, 11:07 AM   #9 (permalink)
ya thats possible. idk how to do it though cuz mine is already ic. lets see if anybody chimes in
Old 11-04-2009, 11:17 AM   #10 (permalink)
khaoskustoms's Avatar
You just get a 1st gen intercooler and bolt it in. Then plumb it to the turbo and engine. Try and find a wrecked I/C truck so you can steal as many parts out of it as possible, and when your taking the parts out, you will know how to put them back in on your truck.
1994 Dodge Dakota Ext Cab 4x4. 4BTA Cummins, 15.09 @ 88mph 1/4 mile, 206hp @ 2700rpm and 446ft/lbs @2200rpm
khaoskustoms is offline   Reply With Quote
Old 11-04-2009, 11:21 AM   #11 (permalink)
thats what i was thinkin. or he could rig up a better ic out of a newer truck... just sayin
Old 11-04-2009, 11:42 AM   #12 (permalink)
i think i'll take the easyiest way and try and find a first gen intercooler. Do the first gen ic motors have a differnt turbo? Thanks for the help so far lol
