| 89-93 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#14 (permalink) | |
'91.5 D350, 2wd Dually, 4" Straight Pipe, 366 Spring, DennyT Stage II Fuel Pin, Isspro Boost, Pyro, Tranny and Fuel Pressure Gauges Brothers: '97 2500, 12 Valve, 4wd, 5spd, 716rwhp, 1200+rwtq, Single turbo, Fuel only |
#18 (permalink) |
The 1st gen IC's WONT bolt in to a 89-91 truck, they have a different rad support in the front. Turn the pump up a bit, get a free flowing exhaust and chop up the intake box. Get a boost and pyrometer. You should have some decent grunt with that.
90 D250 4x4 - Hacked intake, fuel screw turned, 21psi
#19 (permalink) |
is it just the rad support or does the rad sit closer to the front, if its just the support braket i can modify but moving the rad is out of the option. thanks gona make baby turns on the pump
#20 (permalink) | |
1ST GEN MODERATOR
![]() Join Date: Nov 2007
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto, 3:07's axles, 2" skyjacker lift, B&W flatbed |
#21 (permalink) |
It will take work to get it to fit. Its not a bolt in application. Its really not hard, but I was just saying its not bolt in. You need to make mounting tabs and brackets.
