Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 11-02-2009, 04:55 PM   #1 (permalink)
jfc
jfc's Avatar
Power Steering and Brakes
My power steering doenst work, and my brakes ar hard as a rock the last couple days. Its been 5 degrees below freezing. Once I let the motor warm up its fine. My breaks are super touchy then too, I keep locking them up around town,
92, 250, ext cab, 4x4, 5 speed
jfc is offline   Reply With Quote
Old 11-03-2009, 04:25 PM   #2 (permalink)
jfc
jfc's Avatar
my power stering fliud was a little low, I will see if that helps, a mechanic told me to check out the line from the break booster to the vacuum pump near the ps pump, I checked it out, and it seems soft, but no cracks, could this be a problem?
Old 11-06-2009, 03:40 PM   #3 (permalink)
Left out in the cold's Avatar
I've noticed some PS fluids get thicker in the cold. One car I had you needed to rock the steering wheel back and forth to get things flowing. Grabby brake could be contaminated linings, but a hard peddle when cold, that's a new one on me.
91.5 I/C W250 5sp 3.07s turned up pump 16cm2 M&H M2 BHAF Bosch +40s
92 W250 Xcab auto 3.54 bonehead stock
Left out in the cold is offline   Reply With Quote
Old 11-06-2009, 04:00 PM   #4 (permalink)
jfc
jfc's Avatar
this seems to have gone away, mind you its been fairly warm lately, and maybe its hard to tell with it running so rough
Old 11-06-2009, 09:39 PM   #5 (permalink)
I had the same power steering problems on my truck, when it was cold it took a bit before it would work, I flushed the fluid because the stuff in there was all dark and grungy looking. Havent had a problem since. Also had the touchy brake deal, probably fluid on the shoes (brake fluid or gear oil) in my case it was a leaky drivers side wheel cylinder.
93 W250 CC, POD`s, pump tweaked, 35/40, 4in & BHAF
chrislib is offline   Reply With Quote
The Following User Says Thank You to chrislib For This Useful Post:
jfc (11-07-2009)
Old 11-07-2009, 01:39 AM   #6 (permalink)
jfc
jfc's Avatar
thanks chris I will check it out, I put some of that lucas crap, in my ps in the summer hoping it would stop a leak, it didnt, and i wouldn't recomend using it if you live in a cold climate, it gets pretty thick, I bet you couldn't get it out of the bottle at 15 degrees below freezing,( as I was gonna add more the other day) I think I will flush it out
