Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 11-01-2009, 10:28 PM   #1 (permalink)
Thumbs up Getrag 360 input shafts
Does Anyone Know Where I Can Get An An 1 3/8 Input Shaft For The Getrag, I Want To Put The Big Twin Disc In For Sled Pulling
89 W250 RCLB,4X4, Small lift, 35s, 410 gears, getrag, gauges, 99 PS I/C, Masterpower turbo, old smoky pp, south bend con O clutch, 4" exhaust, pods, 366 gs, front air bags, custom hitch, 60lb valve springs, ARP stud kit, multilayer gasket. DYNOED 382hp 730ft/lb
recyclediron is offline   Reply With Quote
Old 11-01-2009, 10:44 PM   #2 (permalink)
I don't think anyone makes one for the getrag. You might want to swap in a nv 4500 if you're going to sled pull with much power over 450hp.
07 5.9 4x4 G56
mdavlee is offline   Reply With Quote
Old 11-01-2009, 11:32 PM   #3 (permalink)
oh why do you think the 4500 is stronger? they have finner cut teeth on the gears and the oil for them is expensive, not to mention 5th gear falls off, my getrag was starved of oil (underfilled from factory) for 300 thousand miles when i got it out of a doner truck, and it still works flawlessly, i dont really want to swap it out, doesnt kta's getrag put down 627 hp through a getrag?
Old 11-02-2009, 01:24 AM   #4 (permalink)
TaterSalad's Avatar
yes it does. ive been wondering this also....cuz if i get a DD for mine then i might as well get a bigger input shaft.
92 W250 club cab 5spd -Eagle Alloys with Discover 35's,4'' rancho lift,K/N filter,4'' silverline exhaust, SW down,2 1/2 turns FPS, SB CON O clutch, autometer boost and pyro,borgeson shaft, cobra 29 LTD NW.custom charger being built. injectors and more soon!
TaterSalad is offline   Reply With Quote
Old 11-02-2009, 10:51 PM   #5 (permalink)
alwaysworking's Avatar
no one makes a big input shaft for the getrag Yet.
i run a SB 3600DD with no issues.
'91 350,4x4,5spd,SB3600DD,60/12wg, i/c,366,M&H fuel pin,twin ram intake,gauges,4" exh.
http://www.youtube.com/user/91ctddc
alwaysworking is offline   Reply With Quote
Old 11-03-2009, 12:14 AM   #6 (permalink)
TaterSalad's Avatar
hey always working what happend to your 3250? just wondering
Old 11-03-2009, 06:29 PM   #7 (permalink)
I never had a 3250, went for the 3600 since they cost the same.
Old 11-04-2009, 03:25 PM   #8 (permalink)
Old 'n Rusty's Avatar
The problem with the Getrag is frequent high-torque, LOW rpm pulling wearing out the input-shaft bearings. This is not a problem with competition pulling. People pull competitively with Getrags all of the time.
91 (08-90) D250
5sp 2wd 497k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'er
R60/7, Volvo 245 GL, f150 4x4 5 spd, Ram 318, MPG's are in Imp gal's
Old 'n Rusty is offline   Reply With Quote
