| 89-93 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
Fuel Filter
Hi, I got a 92 and had my truck run rough at idle a couple days ago (sounded like it was running on three cylinders for about 30 seconds then it recovered) when it was cold out. Thought I would change the fuel filter since I never did it and its been 2 years since I bought the truck. After I changed it it was fine but then the next morning it ran rough, so i thought I should bleed the lines, got that done, this morning it did the same thing, and I noticed I am getting about one drip a minute out of the water drain on the filter, makes me think the water drain valve isnt seatting properly and letting air into the system overnight. Is this possible? anyone else had this problem? I wish I could put a proper plug in there insted of the existing valve. |
#2 (permalink) |
1ST GEN MODERATOR
![]() Join Date: Nov 2007
Yes it is possible. There is another filter that replaces the one we have with the water in fuel sensor. That filer is just a rounded bottom type of filter. I'll have to look around for the number.
93 W350 w/duals, fuel pin turned, 6X.018" injectors, 4" exhaust, 3" air intake horn, Super HX40/16, auto, 3:07's axles, 2" skyjacker lift, B&W flatbed |
#4 (permalink) |
Who's been a dirty boy...
![]() Join Date: Aug 2008
I run the fleetguard FF215 on my 1990, don't think there's a difference between the 89-93's. Just has a drain valve and no sensor, I have never had problems with these and like them because they are a bigger filter
2007.5 Quad Cab 4x4 6.7L ,Automatic, TS Mp-8,S&B Intake, Flo-pro 5" turbo back,H&S Powered!!, EGR Deleted, PATC Line Pressure Booster, Rokktech Crank Sensor 1990 W250 4x4, 5.9L 5speed Getrag, AFC Spring MIA, Pin Modified, Advanced to the max, 2 turns power screw,Piston Lift Pump...TBI PDI Manifold, 2nd Gen Intercooler, DDP Sticks, Phatshaft 66 Turbo www.dirtydieselcustoms.com
#5 (permalink) |
Is the Fleetguard drain valev a push/pull one like the original or is it a plug type that you would use a wrench on? Philip if you can find that number that would be great I am thinkin of adding water seperator, off one of my parts cruisers, on the frame. |
#6 (permalink) |
Am i having the same problem? It starts really rough sputtering then stalls. But if u give it a little gas it runs perfect until i shut it off and let it sit then go to start it. It starts rough...??
#7 (permalink) |
the fleetguard listed above has a drain valve similar to what is used on the rads
#8 (permalink) |
i hought i was having the same problem with my drain valve and then after watching it while it ran, i found out it was coming from the fuel heater sensor above the filter so i wasted money on buying a new drain valve/water senso and then buying a filter w/o a sensor ![]() see: Can find fuel leak? Somewhere right above fuel filter
"If JESUS bore the cross and died on it for me, ought I not to be willing to take it up for Him?" 93 D250 club cab AT HE351CW, 4" DP and custom exhaust ,cooler tubz, Denny T pin, 3200k spring, BLK H2's Last edited by gotacummins : 10-17-2009 at 09:19 PM. |
#9 (permalink) |
1ST GEN MODERATOR
Lok this filter over. Fleetguard FS1251
#10 (permalink) |
Make that a FS 1221. Baldwin BF1221. DP
92 W350 xcab LE, 5spd, 3.54s pump tweaks, piston lift pump, 60mm/ 16cm turbo. plain tailpipe with muffler. For sale |
#11 (permalink) |
1ST GEN MODERATOR
Thanks DP
