Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 10-22-2009, 10:56 AM   #13 (permalink)
powerbrake's Avatar
my bleeder/censor broke and i am now using napa #3472. i do not have a water censor now and i will probably get one later. the napa filter has a screw in bleeder.
92 4x4, fuel screw turned in all the way, starwheel dropped to the bottom, 40 hp injectors, machined pin, detroit locker lets me smoke 'em evenly. auto meter pyro.
God Bless Our Country and Damn The Goverment
powerbrake is offline   Reply With Quote
Old 10-22-2009, 03:27 PM   #14 (permalink)
jfc
jfc's Avatar
that's good, I was going to get the Fleetguard numbers cross referenced at NAPA, as they are the only auto parts store in town.
My problem seems to have fixed itself though...
92, 250, ext cab, 4x4, 5 speed
jfc is offline   Reply With Quote
Old 11-02-2009, 07:50 PM   #15 (permalink)
SheffDodgeD250's Avatar
Which is the part number for the filter w/o the separator?
91' D250 w/ Lil Red Express Bed stacks, Soon to be tweaked FP and Custom fuel system.
SheffDodgeD250 is offline   Reply With Quote
Old 11-03-2009, 12:21 PM   #16 (permalink)
jfc
jfc's Avatar
I believe its these
Originally Posted by dpuckett View Post
Make that a FS 1221. Baldwin BF1221.
DP
Old 11-03-2009, 12:34 PM   #17 (permalink)
powerbrake's Avatar
or napa 3472
Old 11-04-2009, 11:16 AM   #18 (permalink)
jfc
jfc's Avatar
I spoke too soon, barely made it into town today, weird this time it started and idled fine, but was sputtering down the high way and then just about stalling at the lights in town. Usually it starts rough with the air and then gets better.
Old 11-04-2009, 11:20 AM   #19 (permalink)
Im having the same problem. Ive checked the lines and fuel filter and the lift pump and i don't get where i can be getting air at.
Old 11-04-2009, 07:19 PM   #20 (permalink)
1ST GEN MODERATOR
Philip's Avatar
Air pressure the fuel tank. Throw a couple of PSI in. Then look for drips.
Our fuel system can pull air and not leak fluid.
Old 11-05-2009, 12:19 PM   #21 (permalink)
jfc
jfc's Avatar
I changed out the filter, no difference, (doesnt leak though) barly runs at idle but still goes on the highway, I am getting a new lift pump today, as mine has been leaking since I bought it, hope that works.
Old 11-05-2009, 04:40 PM   #22 (permalink)
Old 'n Rusty's Avatar
Lift pump makes sense... our rotary injector pumps are somewhat self priming, pumping but only to a degree. We can 'limp home' without hurting anything major. It is also possible for there to be enough junk in the tank that a couple of filters will plug fairly quickly and then settle down to normal. A change in drivers and driving styles can bring out all kinds of peculiar behaviors in these old babies. As time goes on the life of my fuel filters has stretched. I bought one last year because I had not changed mine in years. It is still sitting on the work bench.
91 (08-90) D250
5sp 2wd 497k VE 'adjusted', 3200 spring, Pyro, boost, 3.54 ,:thumbsup KN, 1\8" timing bump, 25mpg city 30mpg hiway 20mpg towing 6k 5'er
R60/7, Volvo 245 GL, f150 4x4 5 spd, Ram 318, MPG's are in Imp gal's
Old 'n Rusty is offline   Reply With Quote
