Low Pressure Piston Pump $65? - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 10-01-2009, 09:31 PM Thread Starter
Oregon Fuel Injection has a Cummins Fuel Supply pump part #3936320 listed on their website for $65. Am I mistaken or is this the correct part number for the low pressure piston pump? Isn't that half of what it normaly costs, are there non-cummins pumps on the market?
Here is a link to the page, scroll down to the very bottom,
2nd to last item.
Oregon Fuel Injection, diesel fuel injection specialist, rebuilt turbochargers, injector, injection pumps and diesel performance products.
1993 Dodge D250 (Bubba). ASA Intake, star wheel turned, smoke screw in, M3 pin
darestie is offline
post #2 of 12 (permalink) Old 10-01-2009, 09:41 PM
Those are Delphi part #s. Delphi products are generally very good quality. (Delphi was formerly Lucas Industries)
Evel486 is offline
post #3 of 12 (permalink) Old 10-01-2009, 09:50 PM Thread Starter
So that is the right pump if I wanted to convert my stock lift pump? I read somewhere that #3936320 was an obsolete number. Thats a pretty good price, I just don't want to end up with the wrong pump.
darestie is offline
post #4 of 12 (permalink) Old 10-01-2009, 10:17 PM
Richie O's Avatar
I have yet to hear back but a couple guys have gotten that pump. One person reported a lower then normal pressure.
89 dodge 3/4 4x4, A727 ,3.07 gears, factory L S , powerstroke intercooler, S300, stans exaust with stainless tailpipe, fuel power screw turned?, fuel pin turned to deepest, 3 turns smoke screw, 1/2 turn down on starwheel.
93 W250 ex cab, 6X16's, 60 GDS, rag
Richie O is offline
post #5 of 12 (permalink) Old 10-04-2009, 12:16 AM
ZSkibo's Avatar
There was a big thread on this pump over on another site, I forget which. Apparently it's a low low pressure piston pump that matches output of the stock diaphragm deal. Not an upgrade at all as a new diaphragm is $20 cheaper.
92' W250, rhino liner bed+cab. Pump bombed: timing 18*, #366 spring, New Era 6x18's, #60 exh springs, 2ndGen piston pump (@18psi), BHAF, HX40 (60/65/18 T4), 6" hoodstack, full gauges, 4" PAC brake, Airchime P3, SOLD
ZSkibo is offline
post #6 of 12 (permalink) Old 03-29-2010, 01:33 PM
you can check out some comparison products at Ingersoll Rand Fluids
deidrea8 is offline
post #7 of 12 (permalink) Old 03-29-2010, 03:21 PM
Paccool's Avatar
Cummins Part # 3936320 lift pump is the correct number for the low pressure piston pump for first gens.That number may have been changed, I'm not sure. They will idle around 15PSI and the pressure will drop off as you load things up. The pressure will drop depending on what you have done to the truck. I can drop it to about 4 PSI with the big injectors installed which is not enough. For a mildly modified truck they will work fine.
If anyone finds out there is a new number, let me know and I'll change the number shown in the first gen tech section. There is a thread there called "part numbers for a first gen".
Stan
93 D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust, modified tranny, EGT/boost/tranny/tach gauges, TPS removed, a little chrome under the hood. Mag-Hitec tranny and diff. covers. Rear sway bar. Line-x bed liner, after market seats. Single stage Water/Meth system installed. Oversized intercooler w/3" IC lines.
05 Chevy 2500 HDcrew cab 4x4, Duramax W/Allison, 17" Hummer wheels w/285-70-17 BFG's, Banks intake, ported turbo mouthpiece. Predator programmer, Autometer EGT and boost gauges.
Paccool is offline
post #8 of 12 (permalink) Old 03-29-2010, 06:41 PM
Richard LeBar's Avatar
My local Cummins dealer said the new PN replacing 3936320 is 4988751.
E:
Which PN is the high pressure piston pump that's for the 94-98 ppump trucks?
I think I want to go that route with a regulator.
2003 F250 SD 4x4 3.73 SCSB VE Cummins, 60#, Hamilton pushrods, light home porting, A1 studs, 80lpm injectors, LPLP, home AFC work, stock ground pin, ATS mani (blanketed), s362/68/.7 sxe, 4R100, PCS TCU, gauges, 4" Lift, 35" tires
Richard LeBar is offline
post #9 of 12 (permalink) Old 03-31-2010, 02:36 AM
I have the Lucas low pressure piston pump, and it runs pretty steady at 10psi; pulls down to 9 on a hard run in a stock truck. I'd recommend it only if your stock pump goes out, and you dont have the cash for a Cummins/ Carter pump (i.e. myself, 5mo ago).
DP
HIS- 93 W250 xcab LE 495k, Auto to Getrag conversion, 3.07. Hungry diesel 5x11s.
HERS 04 2500 QCSB, HO, Bully Dog, Air Dog, built auto unknown aftermarket sticks
dpuckett is offline
post #10 of 12 (permalink) Old 03-31-2010, 06:09 AM
First Generation Moderator
Greenleaf's Avatar
I bought a used low pressure Cummins piston pump for 100.00 and felt pretty good at that.
$65.00? I'd say that sounds like it isn't the same thing.
1990 D250/1992 D250 Modified by **Smokehouse Diesel** Ashland, OH
....therefore, my brothers, I want you to know that through Jesus the forgiveness of sins is proclaimed to you. Acts 13:38
Greenleaf is offline
post #11 of 12 (permalink) Old 03-31-2010, 11:15 AM
hey-Hey!!!,
Been considering a piston lift pump myself. Saw a thread showing the usual VE and a higher pressure variant. The higher pressure variant had a stiffer spring and a larger bore piston( the VE one was sleeved down ). Now if this one is otherwise mechanically the same, one could swap springs( if that part is available by itself ) and be good to go.
cheers,
Douglas
1990 D250, NV5600, 16cm housing, PAC brake, TST Kit KDP tab, Powr-Lok'd 3.07, HX35....IC soon
1991 D250, 16cm housing
Douglas2 is offline
post #12 of 12 (permalink) Old 04-06-2010, 05:04 PM
Douglas2- yes, you can do that. DTanklage on 1stGen had some part numbers to use a 2ndGen pump, swap out some springs, and have a high flow, low pressure lift pump. Theory is, you have more volume, but the same pressure as the 3936320 pump.
DP
dpuckett is offline
