80's chevy w/cummins conv. HELP! - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 07-29-2009, 06:39 PM Thread Starter
Was wondering if it would be cheaper to build a crew cab short bed 4x4 chevy & drop in a cummins or just buy a dodge w/one already running i only have $3,500 budget for now i think i could build the truck cheap but not sure on converting it over i have a line on a '92 2500 dodge drivetrain complete from frame down for $1,500 i know the adapter plate for a 400 chevy is $799, flywheel is $400. Was thinking i would just use complete drivetrain except frame would this work & how much money would it take to get it running?
cummins wanabe is offline
post #2 of 4 (permalink) Old 07-29-2009, 07:46 PM
cornman369's Avatar
sounds like it would work with the dodge drivetrain just some cross member work and i think the motor sits pretty high due to the oil pan do some searching on hear there a few threads about it, if your dead set on chevy trans {i dont recommend 400T no od our motors only turn 2800 rpm stock ~64 mph w 3.54's}look in scrap yards for four cyl cummins with chevy adapter plate, ebay has one for ~$500 inclds flexplate, starter, wave ring, and adapter plate, says for 3.3or3.9 cummins but bolts up the same
ch
92 D250
fuller 13 speed and 3.07 swap in progress
99 24v 2500 sport auto
72 International Harvester 1110 soon to be 3-53Detroit diesel nv4500
cornman369 is offline
post #3 of 4 (permalink) Old 07-30-2009, 12:13 AM
BridelessRacing's Avatar
You will have to cut crossmember or body lift the truck.
Mine 2000 TDI jetta 5 Speed 47 MPG every day
Hers 2002 TDI beetle auto 40 MPG
Toy Mercedes 5 cyl turbo diesel powered YJ Jeep runs on WVO
BridelessRacing is offline
post #4 of 4 (permalink) Old 07-30-2009, 12:21 AM
WHITE-NOISE's Avatar
yes ive seen them done, u will have to body lift the chevy to clear the motor,
99 2500 7inch long arm lift , adreniline/pulse, FASS150, 100hp injectors, sheid .093 lines/tubes, ATS hotrod vp44, mitchell clutch, complete THUREN FAB steering setup, nv4500 w/ torque king kit, detroit lockers front and rear.
WHITE-NOISE is offline
