Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 07-04-2009, 03:29 AM   #1 (permalink)
93 stock 2wd; issues with grid htr, OD
My "wait to start" is a sometimes thing, and flickers sometimes when driving down the road. coupled with this, the truck will not shift to OD when the "wait to start" is flickering. The other day I was travelling thru town, hit a bump and the "WTS" light went out, and the OD was again selectable and working. Today we are back to same problems. Cleaned all the connectors behind dash and under hood. I,m starting to think PCM. Any ideas?
Christopher P is offline   Reply With Quote
Old 07-04-2009, 06:54 AM   #2 (permalink)
Weekend Wrencher
prototype427's Avatar
Im new to diesels but is it possible to disconect the heater and see if the problem goes away? or how about disconecting the the sensor where it gets its signal to activate the heater (for trouble shooting puposes only)?I worked on gas engines most of my life so im trying to learn as fast as i can but thought id throw some ideas out. I hope this helps Good Luck!
'79 F-250 Crewcab project on 38's with a '90 Cummins, turned up pump, guages, and now looking for an I/C, and needing a turbo housing
prototype427 is offline   Reply With Quote
Old 07-05-2009, 09:13 PM   #3 (permalink)
1ST GEN MODERATOR
Philip's Avatar
The PCM is located behind the battery. Unhook the main wiring plug. Look into the female side. If you see any terminals that are not round. Take a very small screw driver and gently bend them back to a round shape. Then see if the problems go away.
Old 07-06-2009, 09:19 PM   #4 (permalink)
gotacummins's Avatar
it is possible to disconnect the grid heater, people in the south just keep it disconnected
"If JESUS bore the cross and died on it for me, ought I not to be willing to take it up for Him?" 93 D250 club cab AT HE351CW, 4" DP and custom exhaust ,cooler tubz, Denny T pin, 3200k spring, BLK H2's
gotacummins is offline   Reply With Quote
Old 07-07-2009, 06:26 PM   #5 (permalink)
unixcowboy's Avatar
Some of us in the north do the same thing....
Mine's MIA...
Made it through last winter with no problems..Truck turns over 3 cylinders instead of 2 before starting.
'93 D250 CC '94 47RH auto trans w/clutches and some hard parts, HX40 60/65/17cm hit 34 psi held 31, sticks next, 366 spring w/1 turn clipped, power screw bottomed - backed off 1 turn, modified Ol Smokey's power pin, smoke screw fully out, hat modified to get pin higher - still smokes, 4510 w/4 1/2" intake and heat shield, grid htrs mia, 4" dp into 5" pipe to single 5" stack, 285's rear 265's front
unixcowboy is offline   Reply With Quote
