Go Back   Dodge Cummins Diesel Forum > 1st Gen. Dodge Cummins 89-93 12V Forums > 89-93 Powertrain
Old 07-03-2009, 03:02 AM   #1 (permalink)
What Would Cause This !
WHAT CAUSES AN INJECTOR TO LEAK ? WELL AT AN IDLE YOU CAN'T SEE ANYTHING, BUT AFTER IT RUNS FOR AWHILE AND YOU KILL IT YOU CAN SEE BUBBLES WHERE THE NUT THAT TIGHTENS THE INJECTOR IS !
SICK1stGEN is offline   Reply With Quote
Old 07-03-2009, 08:13 AM   #2 (permalink)
Might need to pull the injector and clean the injector bore,I would put new copper washers in to.You could try to just snug it down some and see if that help's.
oldcool90 is offline   Reply With Quote
Old 07-03-2009, 07:16 PM   #3 (permalink)
1stgen3rdgendodge's Avatar
i agree but if your gonna pull the injectors out to do that you mine as well upgrade
93 W250 4x4 125k auto hx40 recon smoked cab lights lots of body work injectors coming soon 01 2500 4x4 auto 2" leveling kit tail lights silencer ring MIA Edge Juice with Attitude custom 4" into dual 6" stacks AEM gauges
1stgen3rdgendodge is offline   Reply With Quote
Old 07-03-2009, 10:30 PM   #4 (permalink)
BridelessRacing's Avatar
Have you washed the motor recently? Is a valve cover leaking. If it's bubbling with the engine dead it is some liquid heatsinking my guess.
2003 quad cab powered by 91 12 valve ve44 pump with 62 CC head fuel pin 80+ injectors 3 inch turbo with a 48RE automatic. Set up to run on strait waste grease, Biodiesel or NO2 http://community.webshots.com/user/bridelessd7
BridelessRacing is offline   Reply With Quote
Old 07-04-2009, 04:24 AM   #5 (permalink)
Yes I Have Washed It Just The Other Day, And The Valve Cover Leaks . What Do You Mean By Heatsinking? Thanks !
Old 07-04-2009, 10:17 PM   #6 (permalink)
When you kill a hot motor it warms up 40+ more degrees than running temp. I would fix valve cover leak and wash again problem should go away.
Old 07-04-2009, 10:26 PM   #7 (permalink)
booost yooo
mahdey's Avatar
is it diesel that is bubbling out? if so it could be the connector tube o-ring.
2000 2500 QCLB AT, 4x4. Auto to manual to auto swap, Goerend Transmission,150hp sticks, 5" Exhuast, AD 150, ADR/Pulse, twins in the works.
Thanks to Coaltrain Diesel Performance, Rollin Smoke Diesel
Ohio Coal Rollers
mahdey is offline   Reply With Quote
Old 07-05-2009, 03:00 AM   #8 (permalink)
Thanks For The Info Guys Really Helps. I'll Fix The Valve Cover Leak An See !
Old 07-05-2009, 04:49 PM   #9 (permalink)
Worng forum- our injector lines connect directly to the injector body, no connector tubes.
Dan
92 W350 xcab LE, 5spd, 3.54s pump tweaks, piston lift pump, 60mm/ 16cm turbo. plain tailpipe with muffler. For sale
dpuckett is offline   Reply With Quote
