| 89-93 Powertrain Discussion of components that are directly involved in the power production and all that is needed to get and keep the truck moving . Engine , Transmission Ect...NO ADVERTISING |
#15 (permalink) |
Thanks, a buddy of mine actually did the wood job before I installed them. You just take off the dash paneling, remove the message center. Then I wired into a light for ground and constant. Then I did my ignition wire off a radio 12v. You have to cut a couple u cuts in the wood to make it fit snug. For right now I have it held on with some kind of tape. I am going to gorilla glue the wood to the panel later.
92Dodge W250 LE 5spd w/ NV4500 BHAF and 4" Turbo back exhaust 6" lift on 35" eggs |
#16 (permalink) |
Thismachinekillsfascists
![]() Join Date: Jul 2008
For what its worth guys...... I have a non IC 5 speed, and the 1/8 plug was blocked by the bracket. Had to drill an axcess hole. I have never seen a bracket with a "factory" hole.
Louisiana Coalrollers! ![]() VE-P-VP My trucks are modded. ![]() |
#17 (permalink) | |
Admin
![]() Join Date: Nov 2005
Stan 93 D250, PDR Twins HX35&HT3B, 60+# boost,PDR stage 2 head w/o-rings, PDR Cam, modified VE Pump, piston style lift pump, modified 5" intake w/AFE, ATS ported manifold,DTT 89% converter, 4" RIP exhaust, modified tranny, EGT/boost/tranny/tach gauges, TPS removed, a little chrome under the hood. Mag-Hitec tranny and diff. covers. Rear sway bar. Line-x bed liner, after market seats. Front end rebuilt with new springs - 2 " taller now. Single stage Water/Meth system installed. Oversized intercooler w/3" IC lines. 05 Chevy 2500 HD, Duramax W/Allison, 17" Hummer wheels w/285-70-17 BFG's, modified air box, ported turbo mouthpiece. Predator programmer. |
#18 (permalink) |
I don't think any of them come stock drilled.
